W2A intercooler? Thaughts
Postby CelicaGT8 » Mon Mar 07, 2011 5:51 pm
Heya, look at my Corona link at the bottom, go to the recent stuff.
Im changing my intercooler, probably go for a w2a. hav a st205 on in the pics, also have a legacy one, but have hurd they are rubbish?
Cant really put one on top of the engine due to the extracters etc not to mention the intake manifold (not the standard way anyway) and i like getting at my plugs easy.
Any input would be great
PERHAPS
CelicaGT8
Postby Dell'Orto » Mon Mar 07, 2011 6:29 pm
The ST205 ones are better, they have bigger water lines to them, and the heat exchanger is bigger than the Legacy one.
Postby h8wrxs » Mon Mar 07, 2011 10:32 pm
ive always wondered, how do those sorts of intercoolers work?
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby levinguy » Mon Mar 07, 2011 10:42 pm
man, what a sweet intercooler you have there!
levinguy
Postby Dell'Orto » Mon Mar 07, 2011 10:49 pm
h8wrxs wrote:ive always wondered, how do those sorts of intercoolers work?
They're pretty simple really, they have water flowing across the core instead of air(which is why they're fully enclosed) and a heat exchanger in the front of the car which dissipates the heat
Postby Rookie » Tue Mar 08, 2011 12:07 pm
As its a race car ditch w2a and just get a frount mount. The reason being is that the typical W2A intercooler is more about absorbing the heat generated by a decent run through the gears, dissipating some of it whilst heating up, but getting rid of most of it after the pedal has been released.
Have a read through this thread:http://www.performanceforums.com/forums/showthread.php?t=67242966&highlight=water+intercooler
Rookie
Postby sergei » Tue Mar 08, 2011 12:29 pm
Rookie wrote:As its a race car ditch w2a and just get a frount mount. The reason being is that the typical W2A intercooler is more about absorbing the heat generated by a decent run through the gears, dissipating some of it whilst heating up, but getting rid of most of it after the pedal has been released.
That is not entirely true.
A good W2A system is well capable to dissipate continuously. The dissipation depends on the radiator, and if the radiator is of the sufficient size (eg stock ST205 is plenty sufficient), it will dissipate continously.
Although W2A system will run slightly hotter, the temperature will be more consistent, as well as W2A system has higher capacity to buffer the spikes than normal A2A system. It takes much more energy to saturate 1 kg of water versus 1 kg of aluminium, you also get a lot more water in W2A than aluminium in A2A.
The aluminium to water transition is more conductive than aluminium to air. You could have a lot greater surface area on the radiator, without having to deal with lag on the W2A system.
There are many advantages in W2A system for all uses, except perhaps in situations where there is continuous air flow over the intercooler.
The main disadvantages in W2A system are:
1) Cost
2) Weight
3) Complexity
The advantages are:
1) Efficiency
2) Consistency
3) Lag
Postby solitaire » Tue Mar 08, 2011 2:14 pm
So you need a standalone radiator on the front of the car is that correct?
AE92, KZJ120, KDJ120
solitaire
Postby Dell'Orto » Tue Mar 08, 2011 2:36 pm
Yup
Postby MAGN1T » Tue Mar 08, 2011 3:00 pm
All you really need is 2 old air to air ICs. (or in my case, 4)
One you mount up front, modify it to take water fittings. Fill it with water (antifreeze) The other you mount in the engine compartment, the air from the turbo goes through it. Mount that one in some sort of sealed box with water in it. Then all you need is pipes and a pump.
As to how you manage to get it to work, like everything else, it's up to your imagination.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby wde_bdy » Tue Mar 08, 2011 3:19 pm
In theory, if using W2A with a modded A2A core it is best to fill the A2A core with water and run the intake air across the core. Or so my research leads me to believe anyway, don't know whether you would notice the difference.
Callum
wde_bdy
Postby CelicaGT8 » Tue Mar 08, 2011 5:14 pm
Had a front mount, but due to the length of the pipe and partly the size i chose it had a sh1t load of lag. my head hurts
CelicaGT8
