Akane wrote:Well if what fivebob said about the 3S engine is essentially an oil cooled engine, then what about the oil squirters for the bottom of the pistons?
high load -> piston expands -> seized motor?
I did have a problem with my car before where I take it for a good blat (0 to 200kph+) then when I come to a coast at the lights it'll just stall and will not start again for 15mins, turns out to be dying battery (does not like to be overcharged somehow?) and a tuning problem (consistant high load and it didn't like it?). I was thinking why my motor would seize up.
MAGN1T wrote:Insufficient ignition timing, pistons get too hot and too big, maybe combined with not enough piston to bore clearance (although it's stock).
Insufficient timing is easy to spot because the exhaust manifold will be glowing, easy to see in the dark.
An EGT gauge would be the best investment to make.
Another way to tell would be to pull a piston and check the sides for scuffing.
Steve
MAGN1T wrote:An oiling problem will end up with big end knock, not a seizure.
unless your cams seize, then it'll probably stay dead.
Running too lean causes knock.
You can't usually hear knock on turbo motors.
Then you'll have broken ringlands on the pistons and oiled up plugs.
Pulling the timing back makes the EGT go sky high, along with a glowing exhaust manifold and glowing turbine housing.
Steve
328FTW wrote:Everything appears normal then it just kinda stops. Temp gauge will shoot up a bit after seizure due to the exhaust manifold head soaking back to the motor but it's still within limits of what I'd call reasonable.
MAGN1T wrote:How do the sides of the pistons look?
Steve
328FTW wrote:They looked alright last motor, normal wear.
However I'll pull this one apart and look at EVERYTHING really closely. Prior to this I could attribute it to other things but this time there was just no good reason other than something is really wrong here
328FTW wrote:That's the thing, I would assume being a seizure like that I would get 4 corner catching or something but I can't see anything.
RS13 wrote:rollaholic wrote:if it were starvation you'd think you'd still get some death rattle before it shit itself entirely though
If there isn't any piston damage, then it won't be the pistons.. galling damage is very obvious. If it were detonation/timing problems to the level Magn1t describes, he'd hear it, it would run like a sack and the top of the piston would look like the surface of the moon. Running bearings at high RPM can only be a lack of oil, or boost spiking which would also damage the piston.
How many RPMs are "very high"? How much boost are you running? Are you seeing at least 10psi oil pressure per 1000rpm? I have seen a similar problem before, older engine though.. 2TGEU with big cams run to 9,000rpm with no oil system modifications, jammed up mid thrash and ran #3 bearing, timing was spot on and no damage to the pistons other than smashed skirts from the crank. If you've raised the factory 3S rpm limit without dialing in the oil pressure to suit then I'd consider that a possible cause of the failures.
DFECTED wrote:Smashed skirts from the crank is a interesting one?
Users browsing this forum: Bing [Bot] and 19 guests
