xsspeed wrote:anyone had mysterious leaks on a 16v 4age - not the water pump?
Mr Revhead wrote:xsspeed wrote:One weird one I had on a AE82 GT looked like it was leaking from inside the cam cover.
Turned out to be a crack in the alloy water pipe on the firewall side of the head. Was running down that along the cam cover and out the bottom...
Leon wrote:the only really evil one I can think of would be cracked block ... which doesn't really bear thinking about.
Mr Revhead wrote:I was throwing the MAGN1T card
touge_ae101 wrote:within the bellhousing as in the gearbox bellhousing?? no water goes in there?
could possibly be the rubber hose that runs from the back of the waterpump to over by the thermostat housing (if 16V's are the same as 20V's). it is a bitch to get at and could be the problem
