wde_bdy wrote:Quick answer -
Yes, as you refine petrol you get less and less high end product compared to low end product.
Callum
Flannelman wrote:I got told that all NZ refinery does to get 95 is bubble LPG through 91...
The best thing is also Gull, or any bio-fuel using ethanol, is that ethanol has an octane rating of 114. Adding this to 91 yealds an easy 98. A poorer feedstock is needed to make 91.
On that note - octane rating is only needed under full throttle. Some tests with and XR6 Turbo showed up some very interesting results regarding power and ethanol. On E85 (85% ethanol so an octane close to 110) they squeezed out over 350rwkW on stock internals (yet larger fuel delivery system) and found that by running too much ignition timing made the torque curve fall rather than detonate.
So as a fuel, if you have a shitbox (like i do now - 92 telstar) there is no point using anything more than 91.
Malcolm wrote:Ethanol blends will always give worse fuel economy because ethanol's specific energy is much lower than petrol - with E85 you would expect to use roughly 50% more fuel than 98 petrol
ATAl wrote:Do you mean the RON vs MON ratings?
Mr Ree wrote:ATAl wrote:Do you mean the RON vs MON ratings?
No specifically that mate, just the fact that a huge portion of performance car owners refer to our pump fuel as 95 octane, or 98 octance when in fact, it is far lower.
Why oh why cant we have 110 octane pump fuel *sniff*
Malcolm wrote:Mr Ree wrote:ATAl wrote:Do you mean the RON vs MON ratings?
that's not entirely true, as the meaning of "octane rating" is slightly ambiguous. There's Research Octane Number (RON) and Motor Octane Number (MON). Our gas is advertised as its RON value, where a lot of other countries use the average (RON+MON)/2
The difference is in the way the octane rating is assessed, the MON value is typically (always?) lower than the RON and based on a slightly more extensive test (both ratings are tested for anti-knock properties in special engines)
Malcolm wrote:Still, on the fuel use side of things...physics/chemistry doesn't lie, so it had to have been running too rich on the petrol so half the potential energy was pissing out the exhaust ports as unburnt hydrocarbons and CO.
Malcolm wrote:Why? At the end of the day it's just a number, and it's more the relative values of the numbers available that is important when you're at the petrol station, deciding which handle to grab.
Lith wrote:I'd have to check the datalogs, I could be wrong there. I have in my head we went from 60% to 80% IDC for the same load/rpm zones.
Malcolm wrote:Lith wrote:I'd have to check the datalogs, I could be wrong there. I have in my head we went from 60% to 80% IDC for the same load/rpm zones.
Well that's a 33% change for starters (even more if you consider the reduced flow periods on injector open and close)
