Hachiroku wrote:My carby 3t powered TT141 seems to be backfiring on deceleration. Compression is good across all 4 and timing has just been set, plugs and points etc are all new. Any ideas on likely cause?
85AW20v wrote:Carby motors keep sucking fuel through the carb on deceleration so its usually unburnt fuel igniting in the hot exhaust system. If you want a really good backfire, turn off the key going downhill with your foot hard on the throttle then turn the key back on.......
