Levin crashes and burns at Levels on Sunday
Postby STR » Wed Mar 30, 2011 3:33 pm
Shit, that's a big one. Here's hoping for a speedy recovery!!
Having never been to that track before, does anyone know why the rescue crew couldn't get the driver out? Don't they have cutting gear?
I only ask so we can learn from it, 'cos I'm on the Fire Rescue crew for Motorsport Auckland, and we always have cutting gear in one of the cars if it's needed.
82 KP60 4AGTE race car
S.T.R - Shopping Trolley Racing!!!
STR
Postby fangsport » Wed Mar 30, 2011 8:10 pm
STR wrote: does anyone know why the rescue crew couldn't get the driver out? Don't they have cutting gear?
looking at the impact point of the Holden, the front section of the intrusion and front leg of cage have gone inboard and trapped his legs. bear in mind, it's a FWD 4 cylinder shell with a RWD recessed 6 cylinder, so the footwell will be rather narrow.
watching fire/rescue crews cut the roof off a road car is easy compared to chopping a rollcage to enable extraction.
fangsport
Postby RedMist » Wed Mar 30, 2011 9:28 pm
From the photos it looks like a fantastic effort from the track crew. There very quickly and working methodically to get him out of the car while the rear end of the car is in flames. I hope when it happens to me that there is a crew with that skill closeby.
Although more than likely I'll be a marshmellow in the middle of a forest somewhere.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby fangsport » Wed Mar 30, 2011 9:39 pm
RedMist wrote:Although more than likely I'll be a marshmellow in the middle of a forest somewhere.
chances are though, if it happens in a forest, whilst rescue time is longer, you will more than likely only have yourself to blame!!
fangsport
Postby RomanV » Wed Mar 30, 2011 10:18 pm
True, but that's not much consolation when you're on fire. :?
Postby STR » Thu Mar 31, 2011 8:16 am
fangsport wrote: looking at the impact point of the Holden, the front section of the intrusion and front leg of cage have gone inboard and trapped his legs. bear in mind, it's a FWD 4 cylinder shell with a RWD recessed 6 cylinder, so the footwell will be rather narrow.
That's a good point re the footwell. I wasn't criticising the rescue crew at all, putting a fire that size out in 2 minutes is a pretty damn good effort!
Thankfully, I haven't had occasion to use our cutting gear yet, but I imagine, as you said, it's be bloody hard to cut a cage.
STR
