Name this steering arm
Postby CelicaGT8 » Sun Apr 03, 2011 12:54 am
Whats this steering arm off, hub is mr2, car is caldina, engine is 1uz, rack is mr2
CelicaGT8
Postby CXGPWR » Sun Apr 03, 2011 4:37 am
Are you talking about the lower suspension balljoint or the outer tie-red end for the steering?
CXGPWR
Postby Burning Angel » Sun Apr 03, 2011 9:07 am
it could be altezza as the lower balljoint is part of the steering arm/knuckle on those.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby GDII » Sun Apr 03, 2011 10:35 am
Looks like MR2 but it's been awhile since I've looked under my car.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby CelicaGT8 » Sun Apr 03, 2011 11:29 am
talking about the lower ball joint.
Yea i think its off an altezza, but dont have one to look at, let alone an mr2 hub.
You think its off an other mr2? Obviously not the same type as the original sits higher above it as you can see in the pic
CelicaGT8
Postby CelicaGT8 » Sun Apr 03, 2011 12:15 pm
CelicaGT8
Postby YeMs » Sun Apr 03, 2011 1:05 pm
definately not an altezza lower balljoint. as you can see in the toyodiy schematic, the outer lower balljoint assembly (43330k R/H and 43340a L/H) bolts onto the lower of the hub and has the mount for the outer tierod built in. the ball joint points 'down'.
In the picture you have supplied, the balljoint is bolted to the lower arm, and the ball joint is pointing 'up'.
The balljoint in the pic you have supplied is more similar to a caldina/corolla lower balljoint.
Your local Hybrid Elite tech
YeMs
Postby YeMs » Sun Apr 03, 2011 1:07 pm
sorry, after a little closer inspection, maybe? i cant quite see clearly how it attatches. the balljoint still appears to be facing up..
YeMs
Postby soopachargen » Sun Apr 03, 2011 6:09 pm
is it just me or is there space to bolt two tie rod ends on that hub??
When in doubt, down and out.
soopachargen
Postby soopachargen » Sun Apr 03, 2011 6:12 pm
ok, on further inspection and visiting toyodiy that makes more sense
soopachargen
Postby CelicaGT8 » Mon Apr 04, 2011 7:24 pm
Wait... your right, the ball joint faces the wrong way.... It needs to bolt to the lower control arm and then have the steering arm off it and bolt to the hub....
Unless theres another part that goes between the lower ball joint and the lower control arm...?...?
ALTEZZA EXPERTS.... ASSEMBLE!!!!
CelicaGT8
Postby YeMs » Mon Apr 04, 2011 8:03 pm
AUTOBOTS MOBILIZE!
can you dissassemble it a little? or get some better pics of it, how it mounts to the hub etc
YeMs
Postby CelicaGT8 » Mon Apr 04, 2011 8:19 pm
OMG i found some, different from how it was in my mind, my sick sick mind.
So need to know what ball joint and steering arm it is, and i am right about the hub being mr2 sw20?
CelicaGT8
Postby YeMs » Mon Apr 04, 2011 10:12 pm
the balljoint looks like a corolla item. steering arm is definately not altezza. infact i cant figure out what its off sorry.
YeMs
Postby soopachargen » Mon Apr 04, 2011 10:22 pm
its not off an ae86 ke70 etc is it??
soopachargen
Postby CelicaGT8 » Tue Apr 05, 2011 6:19 pm
Its not off a ke70, but is simular. The factory st165 balljoints may even fit it, which would be ssssuper cool.
Its close to a MX73 one
CelicaGT8
Postby CelicaGT8 » Fri Apr 08, 2011 5:59 pm
Bump
CelicaGT8
Postby soopachargen » Fri Apr 08, 2011 10:02 pm
not jzx90 or similar??
soopachargen
Postby CelicaGT8 » Sat Apr 09, 2011 5:42 pm
99% sure they have the ball joint is part of the arm
CelicaGT8
Postby YeMs » Sat Apr 09, 2011 6:00 pm
CelicaGT8 wrote:99% sure they have the ball joint is part of the arm
yeh, will be similar to the aristo, mkII etc etc which are similar to the altezza unit.
YeMs
