Rookie wrote:It depends on which 4AFE head you use, but if you use the late model one, it has the potential to be epic. They are the best 4A head by far with a little work.
KinLoud wrote:My magic 4a/7a compression calculator says you will get 9.8 compression with gze pistons and 4afe head
Standard 4afe compression is 9.5 - Narrow included valve ange = small combustion chamber so the 4afe and 7afe pistons have quite a big dish.
Has the motor blown up? Just stick with common easy 4afe everything.
Looks like a 4agte I know of...
Can't quite tell as the pics don't show the whole car.
Who did you buy it off?
Ken
Bazda wrote:I doubt a 20v conversion will be any more $ than trying to make a 4afe head get those flows.
if you stick on a 20v BT head you can easily achieve 250kw atw on pump gas shown by many people on the forums already.
Bazda wrote:You know head work is not cheap.
Head work is $$$$$$ if you want it done right to get the results.
You can pick up a 2nd hand 20v head and throttles for under $500.
Wack that on, mod your flange on the ex mani and your away basically.
anyhow, your money to waste not mine
Users browsing this forum: Bing [Bot], Yahoo [Bot] and 13 guests
