Dell'Orto wrote:Change your brake fluid before you go, and make sure your pads have plenty of life/put some new GOOD pads in. Make sure your oil is full before you go out!
Girvs wrote:Sunblock because you won't be in your car all day
Leon wrote:Where's that photo/slideshow thing of that Civic on mismatched tyres being turned into spare parts at Pukekohe when you need it ...
Not saying that's what *will* happen, but unless you're an old hand on the track, running lots more grip at the front can increase the risk of that sort of crash.
Girvs wrote:I think the point that Leon is trying to put across is not that it will happen, but it comes down to driver experience with the car and the track. Someone new to the track may be better off on a balanced setup than pushing the boundaries by mismatching and having better grip in one area and less in the other. I can see the advantage to having more grip on the front, but to get that grip you also need to push the tyres more and heat them up. For a first timer I wouldn't be giving it my all.
touge_ae101 wrote:i tend to dissagree. i had semi's on the front for the first 5 or so track days when i first went to the track and only stopped using them cause they wore out to the point where they aren't a lot better than a road tyre.
i think understeer is more dangerous than oversteer in a FWD car. oversteer can easily be solved by holding the clutch in and steering out of it if it gets a bit snappy.
understeer is more dangerous for a first timer as you don't realise it is understeering until its sledging across the track, at which point it is too late.
you won't get nasty oversteer unless you lift off and brake hard. and even then its not uncontrollable.
http://www.youtube.com/watch?v=RGytTRCBmN4
that vid was on the back track at manfeild where the surface is super slippery and it was a result of lifting off quickly and braking too hard over the finish line which was on a bend. kind of a worst case scenario for oversteer in a FWD car.
touge_ae101 wrote:you won't get nasty oversteer unless you lift off and brake hard. and even then its not uncontrollable.
Girvs wrote:Sunblock because you won't be in your car all day.
Users browsing this forum: Bing [Bot] and 24 guests
