Equivalent for SAE 20 diesel oil?
Postby cat007 » Sun Apr 10, 2011 10:35 pm
Ok so maybe I don't know as much about oils as I thought I did
But the manual for my diesel boat motor says to use SAE 20 oil.
I can't find this anywhere. All I can find are things like 15W30 etc....
Is a SAE20 type oil just an old term or?
Postby d1 mule » Sun Apr 10, 2011 10:58 pm
i think oils with numbers like that dont change viscosity with temp like regular oils do.
im fairly sure i was told to and used a sae30 mineral oil to run my motor in.
d1 mule
Postby Rick » Sun Apr 10, 2011 10:59 pm
Postby Jason T » Sun Apr 10, 2011 11:06 pm
Fixing Toyota's since '87
Jason T
Postby cat007 » Mon Apr 11, 2011 8:31 am
Postby cat007 » Mon Apr 11, 2011 8:37 am
Thanks. I understand now
Hunt
Postby CelicaGT8 » Mon Apr 11, 2011 6:10 pm
I know that in modern cars it can be very important, but i use to have a corolla with a 2E engine and the bearings were rooted, so i just put LS90 in it and it ran mint for ages
CelicaGT8
Postby cat007 » Mon Apr 11, 2011 8:37 pm
Dam - I think I've just put the wrong oil in haha - the manual says SAE20 and I think I used 15W30
I guess that means it'll be a bit thicker once it's up to temp.....?
Postby allencr » Wed Apr 13, 2011 8:37 am
Didn't it specify DIESEL and some API code like 'SF/CG', besides the thickness/viscosity???
Diesel stuff has some different additives & specs, I think that's the main point & be surprised if they didn't have that as a priority before the viscosity.
allencr
Postby cat007 » Wed Apr 13, 2011 8:53 am
allencr wrote:Didn't it specify DIESEL and some API code like 'SF/CG', besides the thickness/viscosity???
Yeah it's diesel oil I used
Postby sergei » Wed Apr 13, 2011 9:52 am
Most of oils these days have API diesel rating (eg.: read on the bottle of Magnatec).
Users browsing this forum: Google [Bot] and 28 guests
