ATAl wrote:
The engines swap really easily.
amdeman wrote:After trawling through pages on similar subjects using all sorts of forums, there are no definite answers...
Alex B wrote:To be fair you're never going to fit into OS unless you hate on TS.
ae92 4afe motor uses a totally different head to the ae101 4afe. ae111 4afe uses a different block to ae101 (knock sensor provision)
ae 92/101/111 rear hubs are interchangable the difference is disc type have a smaller flange than drum type ones.
BZG|Bling wrote:amdeman wrote:After trawling through pages on similar subjects using all sorts of forums, there are no definite answers...
I think you need a more specific question...
The answer for each part is going to vary so there will be no one size fits all answer.
amdeman wrote:BZG|Bling wrote:amdeman wrote:After trawling through pages on similar subjects using all sorts of forums, there are no definite answers...
Totally agreeing with you there.
The main reason for asking the knowledgeable lot on here is that as things need replacing, she's done 240+kms, if there is the potential to replace with newer (better?) parts for not much more, that would make more sense.
Also when it comes to availability, there are differences between series.
Newer models have more options than the older ones.
Hopefully that makes some sense?
Kiwi-Corolla wrote:The early AE100/AE101 windscreen washer bottles in the engine bay have a tendency to crack quite badly along the edges due to heat over the years, but Toyota fixed the problem in the AE101 Levins/Truenos from about 94 onwards. The washer bottles are a direct swap.
The 4A-FE/5A-FE exhaust manifold in the AE100/AE101 Corollas are very prone to cracking directly through the middle, but again, Toyota seemed to have fixed the problem in Levins from about 94/95 onwards. Straight swap between the two models.
The AE101 Levin GT Apex front seats bolt straight into AE100/AE101 sedans/hatchbacks. Pretty sure the AE111 seats are also a direct swap but haven't had a look at the seat bolt locations in a while. Will check next time I'm at Pick-A-Part.
The steering wheels are all interchangeable between the AE92, AE100, AE101 and AE111.
allencr wrote:amdeman wrote:BZG|Bling wrote:amdeman wrote:After trawling through pages on similar subjects using all sorts of forums, there are no definite answers...
Yes, that does make some sense but the OP is still just as vague.
Is this about parts that you may think are an upgrade, cause in most cases they're not, they're just different.
amdeman wrote:GREAT info, thanks.
When is the next time for a Pick-a-part mission?
With any luck over the Easter break, could catch up? NOT LIKE A DATE though... LOL!
BZG|Bling wrote:Did I miss the part where you explained which AE101 you have and what engine it has?
Because I have no idea
Grrrrrrr! wrote:Does the ae101 fxgt bumper fit the Levins and truenos?
