ae82 hatch wheel spec help
Post Reply
l3_vin
Post by l3_vin »
Hey guys, havnt owned a toyota in a while but have just picked up an ae82 for a daily. Iam after this look for it:
What wheel spec is needed to acheive a similar look? Iam looking at buying 15x7 / 15x8 +35, how flush will they be? any rubbing issues?
Thanks in advance
metal_sean_head
Post by metal_sean_head »
I dunno if this is much help. But with 15X6.5 and 205/50 tyres it rubbed a tiny bit under full lock.
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
l3_vin
Post by l3_vin »
metal_sean_head wrote:I dunno if this is much help. But with 15X6.5 and 205/50 tyres it rubbed a tiny bit under full lock.
how low is your car? mine is just on king springs by the looks. planning to run 195/50
rx7guy
Post by rx7guy »
Im gona take a stab and say that FXGT is on 13x8 -20 ish. 15x7+35 is not going to look stanced. Just normal.
The torque band is wide and the road is narrow
Rob_GTZ
Post by Rob_GTZ »
The AE82 FX-16 pictured above is fitted with 13x10 wheels all round, guards front & rear have been modified extensively
B1NZ
Post by B1NZ »
Just buy a go-kart if you want that tyre look, Im not sure if that picture is taken overseas or not but you do realize that those wheels would be illegal here because they stick out further than the guards aye?
Subaru GF8 Wagon
Subaru GC8 rally car project
Contact:
Post by Bling »
B1NZ wrote:Just buy a go-kart if you want that tyre look, Im not sure if that picture is taken overseas or not but you do realize that those wheels would be illegal here because they stick out further than the guards aye?
Pretty sure it's only illegal if the tread is past the guard
metal_sean_head
Just on lowering springs and shocks. Wasn't that low at all.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
l3_vin
Post by l3_vin »
Rob_GTZ wrote:The AE82 FX-16 pictured above is fitted with 13x10 wheels all round, guards front & rear have been modified extensively
Would you know offset by any chance?
The example i showed is a much more aggresive stance than i want. There arent many pics of modified fx gt's on the net. Will 15x7 / 15x8 +35 fill the guards out quite nicely?
Yep law here is tread must not stick out past the gaurds, and tyres must not have ridiculous streach. Have had some stanced cars previously with no problem.
DRFTIN
Post by DRFTIN »
15x8 +35 wont fit on the back, my 15x6.5 +42 hit the shock
i'd guess to make a 8" wheel fit you would need +15 or less (combined with a lot of guard work
Contact:
Post by Mr Revhead »
I doubt you could get a set up like that legal in NZ.
Read up on the wheel section in the WOF manual
Rob_GTZ
Post by Rob_GTZ »
l3_vin wrote:
Would you know offset by any chane?
Yeah if I remember right it was 13x10 0 offset all round, tyres were 215/50/13
tsoob
Contact:
Post by tsoob »
good luck finding wheels in that fitment.
then read what rev head said
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
Post by xsspeed »
Easy to get steels like in that pic, but as said that car has had hubs/suspension setup modified in some way that allows them to fit ok.
l3_vin
Post by l3_vin »
Yeah as ive said i wont be going for something that extreme, its just the only example i could find. Now looking at some 15x8 0 offset, hopefully it will work. Worst comes to worst i will look at widened steelies.
Post by xsspeed »
15x8 with 0 offset will stick out from your guards no matter what tyre syou use - will need bolt on guards or similar to be legal.
Will also potentially kill your bearings.
At 15x7 I am going around +20 offset - this may still require some guard rolling.
I'd say at 8 inch wide you will want between +15 to +20 or so.
tsoob
Contact:
Post by tsoob »
I have a set of 15x7 +15 bbs copys here..?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
l3_vin
Post by l3_vin »
tsoob wrote:I have a set of 15x7 +15 bbs copys here..?
you have pm!
tsoob
Contact:
Post by tsoob »
All this talk of fitment got me excited...
15x8 20p 2 piece work miesters in white... On my car = WINNNNING!!!!!
Now just gotta find the cash :D
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
eskimo
Post by eskimo »
tsoob wrote:All this talk of fitment got me excited...
Yea that's look the buisness
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
Post Reply
