by Malcolm » Wed May 04, 2011 9:05 am
The rears fit (I think you might need facelift rear hub carriers though). From memory you might have to slightly modify one of the bolt holes for the top hat. Unfortunately the SW20 rear struts are longer - I converted some to coilovers and put them in the rear of my car and with them wound down so it was sitting on the bump stops the rear was roughly normal height.
Fronts - can't remember what the story is, never tried it.
