C56 gearbox backing plate: what part goes here?
Postby Maximum » Sun May 29, 2011 10:42 am
Can anyone tell me what is meant to go over this hole at the bottom of the c56 backing plate?
If anyone has one - pm me!
Thanks,
-Rob-
I'm after these bits for my facelift aw11:
- Ashtray
- Stereo surround
- Front black grill in front of radiator
Maximum
Postby Rick » Sun May 29, 2011 11:07 am
A plastic cover goes over it (Bottom right hand corner of picture)
There is also a alloy brace to the left of that, "11377" which you also dont have.
Postby touge_ae101 » Sun May 29, 2011 12:09 pm
looks like you are missing the block brace. is that in an mr2 or is the crossmember just not there?
touge_ae101
Postby sergei » Sun May 29, 2011 2:57 pm
On automatic that hole is used to undo the torque converter bolts. I have no idea why is it there on manual, except maybe it is same part on both. Perhaps maybe it is to insect if crank seal is leaking?
Postby Maximum » Sun May 29, 2011 7:12 pm
Thanks guys, I've put a wtb ad up here:
http://forums.toyspeed.org.nz/viewtopic.php?p=845870
- Ashtray
- Stereo surround
Maximum
Postby 85AW20v » Tue May 31, 2011 10:07 pm
There could be 2 types of plates - manual and auto - as mine doesn't have the cutout.
See ya
Simon
85 MR2 20v
85AW20v
Postby Maximum » Tue May 31, 2011 10:10 pm
That seems to make sense. That cutout would allow the torque converter to be unbolted...
Bugger...
- Ashtray
- Stereo surround
Maximum
Postby 85AW20v » Tue May 31, 2011 10:14 pm
Before I fitted the double hump cover, I ran for about 5 years without the bottom half D cover on the old backing plate and never had any issues. I wouldn't wory about it too much. You could always make one up out of sheetmetal and pop rivet it in place.
See ya
Simon
85 MR2 20v
85AW20v
Postby Maximum » Tue May 31, 2011 10:16 pm
Okay - that's good to know.
Yes - making my own piece was going to be plan B :)
- Ashtray
- Stereo surround
Maximum
