KE70 grill swapping
KE70 grill swapping
Postby NOLAW » Fri Jun 03, 2011 7:42 pm
Hey guys
Does anyone know how hard it would be to swap the grill on the KE70 pictured below to the quad/round headlight style grill?
surely someone on here knows :)
NOLAW
Postby Dell'Orto » Fri Jun 03, 2011 7:53 pm
Should fit pretty much straight over, the end clips may be a bit different but the centre ones will be the same
Postby matt dunn » Fri Jun 03, 2011 11:27 pm
pretty sure the width of the actual grill is different.??
Postby Dell'Orto » Fri Jun 03, 2011 11:47 pm
Flat front definitely is, not so sure on the sunken front though
Postby matt dunn » Sat Jun 04, 2011 12:02 am
Dell'Orto wrote:Flat front definitely is, not so sure on the sunken front though
I will have a look next time I am in the garage if I remember,
I have about 1/2 a dozen of each or so.
Postby NOLAW » Sat Jun 04, 2011 12:19 am
it looks the same length? can you check for me matt? would you be keen on selling me a grill matt :)
NOLAW
Postby AE25 » Mon Jun 13, 2011 11:25 pm
not 100% sure but..
guards and bonnet interchange. the valence just below the headlight wont. the headlight surrounds step down and interfere with valence. you'll need the twinlight grill to match them unless you shorten and munt it
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
Postby matt dunn » Mon Jun 13, 2011 11:46 pm
Was in the garage tonight for the first time in ages,
all the grill's I have are the sunken headlight type as that is what I run.
I must have got rid of all the rest.
