strx7 wrote:get a altezza engine and put forged pistons and rods in it. variable cam timing is where it is at and the block and crank is the same strength as the turbod ones
RedMist wrote:I gather this is because people think the head flows better on the Altezza?
strx7 wrote:RedMist wrote:I gather this is because people think the head flows better on the Altezza?
it does have a hunt around the net, it appears to flow around 30cfm more in standard form. and vvti over non vvti anyday for broader power band and quicker spool up
iOnic wrote:I doubt the Altezza engine would fit under the bonnet especially with the extra height of the manifold. I'm sure it is doable but it would cost far more than is practical. If you really want a turbo beams why not go for the redtop engine modified for boost?
Malcolm wrote:Far more than practical? Pretty much just a new intake and exhaust manifold... Also I would think the issue with the Altezza intake manifold would be the plenum hitting the firewall when tilted back for the ST205, rather than having insufficient bonnet clearance
