2LTR Rona wrote:What application? ? Road car or a race car??
Road car i'd go as close to OEM as possible, so you can set & forget mentality, unless you are happy applying lubricant every x amount of km's ie Nolathane
Flannelman wrote:Rear nolathane sway bar mounts. $20, tightned up the rear end ALOT on the levin
Dell'Orto wrote:No need for upgraded links, new ones will likely be enough of a difference.
Bazda wrote:The normal off the shelf Nolathane is what people use.
You can search for the bushes you need here
http://www.nolathane.com.au/
Users browsing this forum: Majestic-12 [Bot] and 29 guests
