car jolting/bunnyhopping
Postby Cakky » Wed Jun 15, 2011 6:40 pm
Just started over the last week or so, driving down the road 50-60km/h 4th gear, car will feel like it is jerking/bunnyhopping and when taking off from a stop in low revs crawling along slowly seems to be particularly bad and starts hopping quite badly - quite :oops: really when everyones watching you thinking your some learner driver or something.
a friend ( gasman ) had a drive of it last night and he seems to think its most likely an electrical fault, thinking TPS possibly? Also going to try some new plugs because it hasn't had any in a long time and possibly new distributor?
Also for quite a while after the car has got wet or the roads are wet have noticed a small squeaking sound after lifting off throttle, could this be related at all? Maybe a worn mount?
Cakky
Postby B1NZ » Wed Jun 15, 2011 9:16 pm
Possible engine mount?
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby touge_ae101 » Thu Jun 16, 2011 12:08 am
what other signs are there that something might not be right? when it bunnyhops is it misfiring or running on 3 or just jerky?
hasn't got a vacuum leak or anything simple like that? also might pay to check timing and make sure its not too far advanced etc.
touge_ae101
Postby Cakky » Thu Jun 16, 2011 1:00 am
just jerky mainly, it does feel slightly down on power really low down - but can't remember if thats normal for a blacktop haha. doesn't seem like its misfiring or a cylinder down, to me it seems like the revs do hunt a bit, but not enough for the amount of jerkyness its got? it's weird.
Cakky
Postby touge_ae101 » Thu Jun 16, 2011 10:15 am
checking the codes will tell you if any of the sensors are not working but past that i would be looking at both the MAP and TPS sensors and if they have any vacuum leaks going to them.
touge_ae101
Postby sergei » Thu Jun 16, 2011 10:28 am
Leads/Distributor/Plugs/Coil is first thing to check, it sounds like it is misfiring.
Postby Quint » Thu Jun 16, 2011 10:44 am
+1 for dizzy or tps.
Quint
Postby Cakky » Thu Jun 16, 2011 12:32 pm
tried diagnosing but no codes something to do with when we wired the conversion up I think is the reason that doesn't work. will try the tps, sparkplugs etc and see how that goes
Cakky
Postby Cakky » Sat Jun 25, 2011 12:28 am
changed the plugs no luck.... going to try swap another coil into it tomorrow, leads look fine - Might need to check if the belts slipped a tooth? It's got me stumped. A mechanic friend will be on hand tomorrow anyway so hopefully come to some sort of conclusion
Cakky
Postby gasman » Mon Jun 27, 2011 10:26 am
i got a spare coil and ignitor you can have to try if you want.
"What can possibly go wrong?"
gasman
Postby ~SlideWays~ » Mon Jun 27, 2011 10:33 am
Had same problem with ST ae101, tried everything already mentioned. One last thing I was going to try was opening up the ECU and see if it had leaky capacitors, might be an option for yours?
~SlideWays~
Postby sergei » Mon Jun 27, 2011 12:07 pm
+1 for the leaky caps.
Have fixed them in mine, but symptoms were slightly different: VVT would engage randomly on idle, the idle would be rough because of that.
