Caldina: GTT Strut brace - Trying a workaround...
Postby Sick Puppy » Wed Apr 20, 2011 5:47 pm
Does anyone know if a GTT Strut brace fit non-turbo models? I’m wondering specifically about the braces’ height to get over the intercooler when in a GTT– if I try to fit it to a non-turbo’d one, will it fit under the bonnet?
They have the same towers/ distance, just wondering about internal clearance is all.
I have done a search, and nothing comes up. Thanks!
Project thread here
Discussion thread here
Sick Puppy
Postby gt4dude » Thu Apr 21, 2011 10:44 am
Factory isn't it the same style as a Celica ? strut to firewall to strut but not strut to strut?
Anyways, all strut bars for celica GT4 fit regular celica, theres no bonnet or IC clearance issues at all. some people have this weird idea that the 3s-gte is a super tall motor even when tilted backwards, but they don't realise even with the intercooler on it still sits lower than the strut towers
Should be the same story with the GT-T
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby 1I1 » Thu Apr 21, 2011 11:20 am
Nah Caldina is strut to strut
TRD Clicky >>Here
1I1
Postby Sick Puppy » Thu Apr 21, 2011 11:44 am
gt4dude wrote:Factory isn't it the same style as a Celica ? strut to firewall to strut but not strut to strut?
Thanks for that!
Yeah, like 1I1 said, it's strut to strut, I've seen a TRD one that has both strut to strut and to the firewall, but I don't think I'd have picked that up for $20! :P
It looked like mine had one at some point, and it isn't there any more, but not for long!
Project thread here
Sick Puppy
Postby gt4dude » Thu Apr 21, 2011 2:21 pm
Well the GE and GTE are roughly same height, one has an intake manifold curled over the top, the other has an intercooler on top.
The 3S-FE has a taller rocker cover, but still not taller than a 3S-G* with a cooler or manifold ontop
From what I can tell with the bonnets, the GT-T isn't really bulged much in the middle any more than the GT.
These same questions always come up on the Celica forums. Will the TRD 3-point brace clear the top mount intercooler? will it fit under an NA hood? will a 3s-gte swap with top mount w2a cooler clear the NA hood?
200AWKW / 370NM
gt4dude
Postby Sick Puppy » Thu Apr 21, 2011 8:23 pm
gt4dude wrote:Well the GE and GTE are roughly same height, one has an intake manifold curled over the top, the other has an intercooler on top.
I didn't even think to check 6gc.com, but then it's for a Caldina, and there aren't many of them in the states... and I haven't seen many Caldina GTT's up close anyhow... oh well, slowly but surely it's coming together... ;)
Project thread here
Sick Puppy
Postby Sick Puppy » Sun Jun 26, 2011 1:12 am
Alrighty then, I purchased the brace in the end, cost me the princely sum of about $30 incl P & P! Yay! Got the brace in the post:
Ta-da!
Now, does anyone have any advice as to how the heck I fit this?! It seems to not fit… right now, I’m about 10mm out:
Also, what about the plastic mounts that are already on the towers?
Are they meant to be there for Caldinas without the brace, and do I remove them / replace them with the brace, or leave them as is? I'm thinking remove them...
I know there are two ways of installing braces, one is to undo the strut nuts and install while it’s on the ground, the other is to raise the car and take the load off of the struts. So, who's done this before then? As always, help for this n00b much appreciated - thanks!
Project thread here
Sick Puppy
Postby snwtoy » Sun Jun 26, 2011 12:21 pm
Sick Puppy wrote:Also, what about the plastic mounts that are already on the towers?
Can you take a pic of the whole top of the tower, slighly zoomed out? And re-upload the pic of the brace, as it's not showing here.
snwtoy
Postby Sick Puppy » Sun Jun 26, 2011 10:55 pm
snwtoy wrote:Can you take a pic of the whole top of the tower, slighly zoomed out? And re-upload the pic of the brace, as it's not showing here.
8O D'oh! No idea what happened there, they were right when I posted... Correcting now!
Here is a pic of the rough/test fit - haven't taken the nuts off or anything:
And by mounts, I don't mean the top caps, I mean the plastic C-shaped part attached to the tower by the strut nuts...
Project thread here
Sick Puppy
Postby snwtoy » Sun Jun 26, 2011 11:19 pm
Hokay
For what it's worth, the brace looks identical to mine.
I've always removed and re-attached mine while at least one wheel was on the ground.
The rubber/plastic bits ... I don't have them. WTF could they be for? Lose them imo. They look like spacers so the nuts sit correctly when you do not have a brace.
I would jack the whole front up and see if you can fit it. 10mm of chasis flex is conceivable. You will need to go for an alignment after you fit it.
snwtoy
Postby Sick Puppy » Mon Jun 27, 2011 12:05 am
snwtoy, cheers for that, I was wondering if they were spacers. I'll have a crack at it this week, and see what happens. It's getting WoF'ed this week, so I can add an alignment to the mix too. Thanks!
Project thread here
Sick Puppy
Postby Bling » Mon Jun 27, 2011 12:39 am
10mm out is a bit weird. was that with it sitting perfectly over the bolts?
I'd just whip the 4 nuts off and see if it fits on while it's sitting on the ground.
Installation - FAIL :o(
Postby Sick Puppy » Tue Jul 05, 2011 9:16 pm
[sigh] only I could take something simple and f*** it up...
BZGBling, you were right - the easiest job in the world... even got to use my socket set properly for the first time too!
But something somewhere is wrong... basically the brace does not measure up with the towers.
I thought I was 10mm out, well, actually it's 20mm, with my not so trusty tape measure a la Mitre 10:
Makes no difference whether I do it on the ground or jack it up at the middle underneath the engine. So, out of the myriad things that could have gone wrong, are:
1. Caldina GTT brace does not fit non-GTT caldinas - unlikely, given consensus here and 1I1 reckons so too. (having said that, can someone please measure the distance between the nuts on their towers please? A GTT and non-GTT would be very helpful here.)
2. My car is buggered - possible I guess, an ex-car dealer friend of mine doesn't like the steering, but I can't see any signs of accident damage. It is high mileage though, maybe chassis is getting old? :? Doubtful...
3. Brace is buggered - plausible, more so than no. 2. I have no idea about the history of the car it came off of, although there is no rippling or damaged paint. I suppose I could get it bent into shape, although that's gonna be a PITA to get it right...
4. I am the muppet to rule all muppets, and should just sell my tools, leave all the forums I'm part of, and stick to watching crap TV soaps with my missus.
Any suggestions anyone?
PS, It's not no. 4, that will result in a slow painful death for me! lol
Project thread here
Sick Puppy
Postby Dell'Orto » Tue Jul 05, 2011 9:20 pm
Jack up one corner of the car, then try. Is definitely a ST2xx strut brace?
Postby Kiwi-Corolla » Tue Jul 05, 2011 9:40 pm
I just measured the length between the two outer strut bolts on a 98' GT-T and the ones on the very far edge came to 1070mm in distance, and the ones closest to the front of the car came to 1067mm in distance. The measurements were taken from the centre of each stud (in darkness with a torch mind you, but I'm confident with my measurements). I didn't get to measure the distance between the last bolt as my helper disappeared (:roll:), but if those two match up with yours then the third measurement is irrelevant.
Here's a photo, as they tend to speak a million words:
Image :roll:
Kiwi-Corolla
Postby Sick Puppy » Tue Jul 05, 2011 9:45 pm
Dell'Orto wrote:Jack up one corner of the car, then try. Is definitely a ST2xx strut brace?
Will give it another crack tomorrow, jacking up one side. It's come off of a GTT or so I've been told, it looks exactly the same too. :wink:
Kiwi-Corolla wrote:I just measured the length between the two outer strut bolts on a 98' GT-T and the ones on the very far edge came to 1070mm in distance, and the ones closest to the front of the car came to 1067mm in distance. The measurements were taken from the centre of each stud (in darkness with a torch mind you, but I'm confident with my measurements).
[Pics]
Your arrows are so much prettier than mine lol
Looks like it's the strut then... yours match my measurements roughly, although I measured the inside of the nuts. It's within coo-ee for me. :wink: There is a GTT at a wreckers I went to last week, I will go back and see if they still have the brace on it and compare.
Should be getting WoF sorted this week anyhow, will see about making this fit, somehow!
Project thread here
Sick Puppy
Postby Kiwi-Corolla » Tue Jul 05, 2011 9:51 pm
Sweet. I just managed to measure the distance between the last two studs by the way (the ones closest to the engine) and they were 965mm apart.
Kiwi-Corolla
Postby 1I1 » Tue Jul 05, 2011 10:10 pm
Is it possible a bit of pressure and bending in the right places it'll form the right dimensions to fit?
TRD Clicky >>Here
1I1
Postby Anth_555 » Tue Jul 05, 2011 10:23 pm
i dont think jackin the car up to get the brace to go on is agood idea. the idea of a brace is to reduce movement not hold something in place. there realy is only to reasons why it wont fit. 1 its the wrong brace or 2 and most likly its bent
cars can flex alot. and to twist a car so much to get a brace to fit can only make more problems then good
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby Dell'Orto » Tue Jul 05, 2011 10:32 pm
True, but what about if its been bent that way, could be a sweet/rangi DIY chassis machine :lol:
