LEAKER wrote:So sometimes my cooling fans work and sometimes they dont. Obviously this is when the car is up to the correct temprature. Any common faults or ideas on where to start fault tracing. It has 2 fans and neither of them are kicking in so im thinking its an issue with either the wiring or the relay.
The fuse box has seen better days and the wiring is in fairly poor condition.
THe temp sender has been replaced
Ideas??
LEAKER wrote:i dont run aircon. have my aircon fan hooked up to feed of my engine cooling fan and both of the fans run sometimes and then both of them dont other times.
