LEAKER wrote:... a complete waste of time
Adoom wrote:LEAKER wrote:... a complete waste of time
As I see it, you would get not enough air and it would be at the wrong time.
The pressure difference would also probably be wrong and you would get exhaust going backwards through the BOV instead of the excess intake charge going out. Shit you don't want hot would end up getting hot. You would be better off hooking some compressed air or something up to the exhaust housing to spool it up faster when you mash your foot down. Not sure that would work either.
Malcolm wrote:On the ST205 Group A models, there was a system similar to what you describe, as part of the non-functional antilag system. I'm not certain whether the purpose of this additional air was to provide some cooling to the exhaust components to mitigate some of the premature failure of components that antilag can cause, or whether it was to provide fresh air to help the fuel combust in the exhaust runners to make the system more effective.
CelicaGT8 wrote:AFM has registered the air coming in, and if it wasn't there it would make it run rich for a split second?
VR-4Squid wrote:CelicaGT8 wrote:AFM has registered the air coming in, and if it wasn't there it would make it run rich for a split second?
Throttle is closed, engine rpm is (way) above idle, therefore fuel injected = zero.
Internet/magazine myth #2296 debunked.
