Quick Quesrry about 4AGE Bore Size!
Postby FYADUP » Tue Jul 12, 2011 10:00 am
Hey guys,
I am selling these pistons on trademe -
http://www.trademe.co.nz/Browse/Listing ... =390950151
I haven't answered it yet, but have a guy asking if these would fit the standard blacktop bore?
On the net I have found the standard bore size of 81mm
On the box of my pistons its says 3.209 inches, which when converted to mm is 81.5mm - does this mean no, it won't fit standard bore and is 5mm oversize? or is 81mm I keep seeing on the net just a rough whole number as opposed to being to so many decimal places?
Would be great if someone could shed some light on this :D
Cheers,
Jason
R.I.P - 90 4AGTE GT-i Corolla Hatch [ROLYOU]
New 91' Corolla GT-i project! WATCH THIS SPACE
FYADUP
Postby Vertigo » Tue Jul 12, 2011 10:05 am
yep, oversize. standard is 81mm.
TVIS just kicked in, yo!
Vertigo
Postby Bazda » Tue Jul 12, 2011 10:19 am
Meaning he would have to get the bores re-bored.
Anyhow ALL bores should be honed to suit the new piston no matter what.
Esp if using forged pistons as they require certain tolerances.
The only time you can just drop a piston in there is when you buy another stock one of the same size.
Postby KIPH8N » Tue Jul 12, 2011 12:56 pm
What if you have a silvertop block and drop 4agze pistons in there? Do they go under stock pistons?
KIPH8N
Postby Bazda » Tue Jul 12, 2011 3:20 pm
KIPH8N wrote:What if you have a silvertop block and drop 4agze pistons in there? Do they go under stock pistons?
I would say no.
n/a piston clearance and forced fed clearances are different.
n/a being much tighter.
Postby 4agtepwr » Tue Jul 12, 2011 4:14 pm
Normally as a rule, the clearance is built in to the piston, for example with a 81.5mm os 4agze piston the bore can be finished at the nominal size 81.5. I think from memory they run just on .05mm clearance or.002 thou in old school terms and that is built into the skirt of the piston if you get what I mean. But yes that block will have to be bored and honed to suit those pistons as there .5mm oversize.
There are exceptions to this and piston to bore should always be checked before assembly by someone who knows what there doing.
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
