Mr Revhead wrote:Any sign of leaks? Water has to go somewhere.
toyta wrote:Mechanic had it for the full day today, says all fixed. Picked up just now,no leaks but temperature went from cold to almost half immediately, after driving about 100 m and heater still not working, it was definitely working before? Mechanic says heater not working has nothing to do with the water leaking problem? Any ideas. comments?
gt4dude wrote:I've had this problem with a few Toyotas including my GT4,
(And Carina and Celica use alot of the same shit in the ST20X series)
when the system overheats or boils over I've found commonly that the 1. old thermostats get stuck, 2. old radiator caps warp their seals allowing hot antifreeze to escape and 3. the heater core gets clogged with sludge from old antifreeze and corrosion crap..
