AFM vs trumpets
AFM vs trumpets
Postby R.U.F » Mon Jul 11, 2011 2:47 pm
Looking at putting a silvertop 20V into project tofu. If I remove the FWD airbox and run with individual filters how do you work around the AFM not being inplace?
Drive it like you hate it!
R.U.F
Postby deaf_rattle » Mon Jul 11, 2011 2:51 pm
it wont if you are running stock ecu.
Either get blacktop ecu and loom with sensors, or run aftermarket fuel management.
Postby R.U.F » Mon Jul 11, 2011 3:07 pm
Bugger that puts the cost through the roof
R.U.F
Postby 4agtepwr » Mon Jul 11, 2011 4:09 pm
silvertops run like arse on a blacktop ecu, it kills the mid range and run far to lean, I brought my kp60 racecar running that setup and it was horrible to drive, terrible on part throttle. We ended up wiring in a g4 storm loom and using the link out of my mr2, only made another 5 hp up top but made a much fatter midrange and heaps nicer to drive. From what ive seen a silvertop/blacktop will make more midrange/power with some form of airbox enclosing the trumpets anyway
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby R.U.F » Mon Jul 11, 2011 4:48 pm
Cool thanks. I think the best beat is to just get and airbox made up for RWD and stick with the silver top
R.U.F
Postby Bazda » Mon Jul 11, 2011 5:41 pm
Nice big sturdy airbox, with proper bell mouth trumpets.
Postby touge_ae101 » Mon Jul 11, 2011 7:59 pm
i may have one of bazdas plenums available for sale with 50mm trumpets if you want to go down that route?
or look at either a MS3 or a cheaper link (G1,2,3 will also do just as good a job on a simple ST setup) and just run the blacktop MAP sensor. can be done for under $1000 i'm sure.
not sure how you would run a MAP sensor on ST throttles but i'm sure it can be done.
touge_ae101
Postby R.U.F » Mon Jul 11, 2011 8:20 pm
Cheers touge_ae101. I'll prob stick to the standard computer for now only cos I have a limited budget at the moment.
R.U.F
Postby rollaholic » Mon Jul 11, 2011 8:22 pm
basically if you want to bin the AFM the easiest way will be to get a blacktop.
just do that, they are better anyway :P
Postby touge_ae101 » Mon Jul 11, 2011 8:31 pm
the facelift silvertops are noticably better than the prefacelift ones though, not far off the performance of a blacktop. (megameet 10' dyno day there was about 5kw difference...)
you can tell them apart cause they don't have a stupid twin throttle linkage system on them.
finding a semi decent silvertop is another matter though. they are getting a bit long in the tooth now.
touge_ae101
Postby R.U.F » Mon Jul 11, 2011 9:57 pm
For the sake of 5kw the blacktops are always way more expensive.
touge_ae101 got a better description of how to tell them apart?
R.U.F
Postby touge_ae101 » Mon Jul 11, 2011 10:24 pm
R.U.F wrote:For the sake of 5kw the blacktops are always way more expensive.
prefacelift: notice 2xcams on top of throttles with a link in between?
facelift: notice only one cam which the throttle cable acts on.
http://i63.photobucket.com/albums/h160/ ... 1258206623
sorry can't get pic to work
i think they have a slightly different throttle design and better tune from factory with a few other minor changes no doubt. maybe someone more knowledgable could fill in the differences...
touge_ae101
Postby R.U.F » Mon Jul 11, 2011 10:31 pm
Cheers for that!
R.U.F
Postby rollaholic » Tue Jul 12, 2011 8:47 am
i believe sergei discovered some differences between the injectors too (more holes in facelift version resulting in better spray pattern or similar)
as for the price difference, you get a motor thats not only newer, but better too. as mentioned above, most silvertops are on the old side, and have mostly been thrashed mercilessly by people like me.
as the old saying goes, (i think fivebob might have started this one, hah) 'quality is appreciated long after price is forgotten'
Postby R.U.F » Tue Jul 12, 2011 9:37 am
Yeah can't agree more. I'd rather pay a couple of hundy more for a good low Km motor than for a thrashed P.O.S I have to rebuild
R.U.F
Postby R.U.F » Wed Jul 13, 2011 5:28 pm
Thanks guys I went and bought a black top today so no AFM worries.
R.U.F
Postby rollaholic » Wed Jul 13, 2011 5:31 pm
sweet, looking forward to pics :P
Postby R.U.F » Wed Jul 13, 2011 9:14 pm
yeah will get some pics as it comes together. Gonna do gaskets and big ends before I install it so will be some time. Need to sus out a plan to wire it up so will post new thread
R.U.F
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
