Hey every one, whats the level of diffuculty?
Can you drop the gearbox down the bottom using a hoist as such.
Has any one done this before?
Also how much oil will the gearbox need.
James
edwagon wrote:Top bellhousing bolts are the only tricky bit - need to undo gearbox mount and lower the rear of the trans to tilt it back, and use several long extensions to reach up to the bolts - you will need ~3 feet of extensions.
Jonno2002 wrote:lol heres method 3 the easiest of the lot, flex sockets:
these should be called the best god dam tool ever invented!
autos are the easiest cause they drop strait out, no spline to worry about, just REMEMBER to take the flex plate bolts out through the oval access panel at the back of the sump.
Quint wrote:edwagon wrote:Top bellhousing bolts are the only tricky bit - need to undo gearbox mount and lower the rear of the trans to tilt it back, and use several long extensions to reach up to the bolts - you will need ~3 feet of extensions.
I lay on top of the engine and reach down the fire wall with a spanner, do the top two + top start motor bolt.
many ways to skin a cat.
edwagon wrote:Have done this many times
Other than that, the converter bolts are easy and there is plenty of room - shouldn't take long
