strx7 wrote:if it injected water into the cylinders,
matt dunn wrote:If water made it to the injectors they will be stuffed.
Water molecules are bigger than Diesil molecules
and dont fit through the clearances in the injectors.
Usually they will blow the end off the injector.
But water doesn't usually make it that far as same goes for clearances in the pump.
Grrrrrrr! wrote:lack of lubricity
gleem wrote:yes water did make it to the outlet of the injector pump which isnt good. this happened just over a week ago. How big are injector caps? big enough to damage internals? after diesel flowed to the pump outlet i hooked it up but still didnt start
gleem wrote:ok its a 3ct 1996. How do i know if its eletric or not?
Sorry dont know shit all about diesels
