Metal screws into plastic
Postby FST4RD » Sun Aug 21, 2011 10:18 pm
Technically a car question... RC Car.
Having a couple issues with screws coming loose in my offroader.
Went racing today and 3 came loose :x
Is there any kinda locktite type substance that I can use on metal screws to hold it into the plastic?
Plastics not stripped either.
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Re: Metal screws into plastic
Postby RS13 » Sun Aug 21, 2011 10:25 pm
FST4RD wrote:Technically a car question... RC Car.
Loctite do make a plastic glue, but it works by melting the plastic together, probably not what you want. Tried shakeproof washers?
RS13
Postby FST4RD » Sun Aug 21, 2011 10:30 pm
No room to fit them... Had thought about that though.
Someone mentioned to me superglue?
What about model cement?
FST4RD
Postby RS13 » Sun Aug 21, 2011 10:34 pm
Model cement works much the same, melts the two plastic surfaces together to form the bond. If there is enough room you could drill the heads and lockwire them?
RS13
Postby Simon K » Sun Aug 21, 2011 10:43 pm
Personal experience...remove the part, clean around the screw holes then put one drop of super glue onto the hole and "blow" it in. Let it cure and then the resulting hole will be somewhat stronger than it was. Depending on the brand, some plastic parts are not much chop. Also some aftermarket screws have finer threads than OEM ones. I bought some 3 Racing Titanium replacements for a Touring car and the threads were noticeably smaller.
I used to do this regularly to steering knuckles as the lower screw holding them would often work loose.
Simon K
TS Wannabe
Postby FST4RD » Sun Aug 21, 2011 11:23 pm
Yeah i have an issue with the suspension arm screws coming out. I can swing off the screw driver and they go in tight, no stripping, feels solid... but I'm having to tighten them after each run.
Might try the super glue thing.
FST4RD
Postby Dell'Orto » Sun Aug 21, 2011 11:39 pm
One of the low strength Loctite thread lockers no good? I think 222 is one for small/fine thread screws
Postby rollaholic » Mon Aug 22, 2011 8:05 am
loctite have a pretty big range these days, go have a nose - plenty of info on the bottles about applications etc
Postby LEAKER » Mon Aug 22, 2011 8:21 am
Loctite super glue would probably be your best bet. Its pretty strong stuff.
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Postby FST4RD » Mon Aug 22, 2011 10:42 am
Thanks guys...
One of the things is that I have to be able to get the screw out. Everytime I go out racing I have to pull most of the car to bits to clean it.
FST4RD
