Isolate the system:
Loop the heater
Loop the Oil Cooler
Get the cooling system back to basics.
Get the radiator checked (rodded?) My first "aftermarket" was shite - Custom made one fixed all my problems because it actually flowed!
Check for corrosion in the water pipes and fittings (remove all fittings on block)
Get the water passeges in the head checked and cleaned while the head is off.
trd-drifting wrote: ...a kinked heater hose line which i do not think is the root cause of the problem but defintly is adding to it. Cannot believe i did not see this in the car. water still runs through it but just.
allencr wrote:If it's not a BHG & not an impeller less waterpump & not a clogged radiator internal/external & not an air flow problem & not an engine swap hose routing problem like trying to draw from the radiators upper into the engine, then I don't have a clue. Sorry. Good luck.
Also, sure it's not a gauge problem?
I agree, overheating faults are not hard to rectify. This is how I go about every overheating fault that comes into work.
1 - TK - Chemical check
2 - Pressure test system
If both these checks are fine you have a flow problem.
3 - Thermostat
4 - Remove radiator and rod
5 - Water Pump (Corroded or detached Impeller)
Just make sure you have no airlocks in the system when topping up coolant, if it keeps boiling over let it cool down and just keep topping it up. Thats all there is too it. Dont get too technical and overthink things, cooling systems are very basic.
MAGN1T wrote:Pressure tests don't work, like lots of other tests.
The pressure test that's normally done is to pump up the cooling system to 15 or 20 PSI and watch it bleed down (or not bleed down).
Don't you think that's a bit pointless when cylinder pressure is in the order of 1000PSI when the sparkplug fires?
So that's 1/50 the required pressure AND in the wrong direction.
The only pressure test that actually works is to fit a pressure gauge to the cooling system and take it for a thrash, watching that the gauge never exceeds the rating on the pressure cap.
That's the only 100% effective test for a headgasket leak.
As for TK tests, they're a waste of money too. Just for mechanics who don't know WTF they're doing.
Steve
trd-drifting wrote:Also what rpm does standard 2JZ turbos kick in as it seems a lot laggier than my 1JZ. I have removed all the little valves and solonoids and the butterfly valve in the intercooler piping so both turbos spool at the same time. Full boost (12psi) took till 3600rpm according to the dyno charts and im sure my 1jz was like 2800rpm.
True-No-Turbo wrote:MAGN1T wrote:Pressure tests don't work, like lots of other tests.
Steve
OMG!!STFU! you have no idea! I have 19 years in the trade and have Trade certificate and National certificate in automotive engineering.
You cant have any mechanical experiance what so ever as it truley shines through your posts. Ive lost count the amount of times you have put people wrong so do everyone a favour and stop posting worthless dribble on this furum! TWAT!!!![]()
rollaholic wrote:jesus.
pressure tester and TK tester both have their uses. they are tools, just like a spanner, or your brain. if you use it in the wrong way, then of course its going to seem pointless.
Mr Revhead wrote:rollaholic wrote:jesus.
ahhhh.....
MAGN1T wrote:The only pressure test that actually works is to fit a pressure gauge to the cooling system and take it for a thrash, watching that the gauge never exceeds the rating on the pressure cap.
