3SGTE tvis.. keep it or remove it?
Postby Grrrrrrr! » Mon Aug 29, 2011 10:48 pm
Just wondering if it makes any noticable difference on a standard gen2 engine.
Just started stripping the 3s, and generally hating on the number of vacuum lines and shit, and want to remove them all so long as its not going to cost me reliability or driveability...
Opinions?
Grrrrrrr!
Postby Al » Mon Aug 29, 2011 11:11 pm
Keep it unless you are building a monster.
Al
Postby iOnic » Mon Aug 29, 2011 11:34 pm
Half the time it doesnt work. Keep if you want, not the end of the world if you don't. Does help drivability....when it works.
Postby loudstealthGT-Four » Mon Aug 29, 2011 11:40 pm
has any one ever seen any dyno plots of t-vis vs no t-vis, id be keen to see the difference as im thinking of removing it as well, while my motors out
EDIT
to answer my own question did abit of research and it seems that if you want more power from a relatively stock 3sgte then keep the T-VIS and tune it with a MSD RPM switch
http://www.mr2.com/forums/turbo-engine- ... nator.html
but if you haven't read this before, then id recommend it
http://www.mrcontrols.com/primers/power.htm#link1
Last edited by loudstealthGT-Four on Tue Aug 30, 2011 12:17 am, edited 1 time in total.
loudstealthGT-Four
Postby Al » Mon Aug 29, 2011 11:56 pm
I've got my old dyno plot here, lost the image of it so I'll have to scan it again.
You can see where the TVIS butterflies opened on my old car on the plot, the boost spiked along with the HP and TQ.
Al
Postby sergei » Tue Aug 30, 2011 8:51 am
I had to remove mine and "port match" the manifold because the diaphragm was broken inside of actuator and Toyota wanted a kidney for the replacement part (and all actuators I found on pickapart were broken).
Postby Heylin » Tue Aug 30, 2011 6:17 pm
When I had mine tuned back in January they showed me the two plots with and without, the torque crossover point was the best point for opening. Yep it made a noticable difference in low end.
Heylin
Heylin
Postby Dell'Orto » Tue Aug 30, 2011 7:38 pm
Unsurprising really, they have monstrous ports.
Postby LEAKER » Tue Aug 30, 2011 7:55 pm
So how would you test if the t-vis is working correctly. Now that this has been brought up id like to have a look into getting mine set up right.
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Postby CelicaGT8 » Tue Aug 30, 2011 9:14 pm
I got rid of mine, been fine without it
CelicaGT8
Postby EssDub » Tue Aug 30, 2011 10:22 pm
LEAKER wrote:So how would you test if the t-vis is working correctly. Now that this has been brought up id like to have a look into getting mine set up right.
This.
I'm sure mine isnt working right...
1992 SW20 MR2 GT-S Turbo
Previous Rides: Mazda 323, Toyota Levin BZ-G, 1992 SW20 MR2, 1994 Gen3 SW20 MR2 T-Bar
EssDub
Postby Dell'Orto » Tue Aug 30, 2011 10:37 pm
Pretty sure the BGB has a method for testing TVIS operation
Postby blindnz » Tue Aug 30, 2011 11:03 pm
cant you just unplug the hose which will disable tvis, should be a physically noticeable difference with it.
Although i guess this wouldnt help if its stuck open
blindnz
Postby sergei » Wed Aug 31, 2011 8:47 am
Apply vacuum to TVIS actuator, it should pull the butterflies completely closed.
Additionally it should hold butterflies closed with no additional vacuum.
Postby Trls250s » Wed Aug 31, 2011 9:25 pm
Drive mr2 with TVIS, a lot more low down torque and go vs gt4. Could also be drag from 4wd driveline.
Tvis in bigport 4age is critical if you want to get off the lights without riding the clutch hard.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby Vertigo » Thu Sep 01, 2011 12:30 pm
why would you want to cripple your engine? O_o TVIS is there for a reason..
TVIS just kicked in, yo!
Vertigo
Postby Malcolm » Thu Sep 01, 2011 1:25 pm
mine's never seemed "crippled" without TVIS :P
Postby LEAKER » Thu Sep 01, 2011 1:29 pm
Trls250s wrote:Drive mr2 with TVIS, a lot more low down torque and go vs gt4. Could also be drag from 4wd driveline.
Huh? Same engines.
LEAKER
Postby sergei » Thu Sep 01, 2011 2:03 pm
That is without TVIS.
TVIS might help with drop in torque below ~3200rpm, but that drop is more due to boost threshold than TVIS (at least I believe). Additionally boost curve is rising because of boost creep (it should have flattened at 10-12psi) as I was running stock CT20b wastegate pressure (un-bled), the only thing that was keeping boost in check is very restrictive el-cheapo 2.5" muffler.
Postby Akane » Thu Sep 01, 2011 6:58 pm
Sorry my photoshop-fu is really shit, and I know sergei is in 3rd gear + 4WD.
But yeah, so sergei's no TVIS vs PowerFC TVIS + GT28RS.
I know it's not informative, but just for shits and giggles :/
red = Akane kW
black = Akane tQ
Blue = sergei kW
Green = sergei tQ
edit: torque is wrong and I don't know how to free transform it correctly :(
Users browsing this forum: Bing [Bot] and 4 guests
