2jzgte removing aircon..what about pulley?
Postby 92mr2paddy » Tue Sep 06, 2011 12:59 pm
ok so i havent had the aircon system working (have removed everything except pump) in years, atm setting up the big single turbo and the Massive air con unit is just sitting on the side of the motor,
only problem is everything runs of one giant ass belt, is there an easy way around this or do i have to get another pully mounted in the same place where the air cont unit is or maybe a shorter belt? anyone done this before.. easily? cheers pat
92mr2paddy
Postby strx7 » Tue Sep 06, 2011 1:45 pm
do a search someone posted up the belt number that you need to run it without the a/c pump pulley in there
Postby MrOizo » Tue Sep 06, 2011 7:11 pm
If you are wanting to keep the damper on the tensioner, you'd be best to put a pulley in there. I tried making enough clearence but the bracket was too thin and failed.
I think the belt is 5PK1340 (or was it 1300?). Pretty sure its 40mm shirter than stock anyways!
MrOizo
Toyspeed Legend
Postby 92mr2paddy » Tue Sep 06, 2011 8:05 pm
sweet so i wouldnt need the damper just the tensioner by itself would work? but i know what u mean i took it off earlier and the belt would run right onto the bracket that the dampener bolts too but if its not needed would be great, cheers pat
92mr2paddy
Postby Mr Ree » Tue Sep 06, 2011 11:30 pm
I believe the aristo motor doesnt even have the damper anyway so It appears they can cope without one.
My NA doesnt have one either :( *sniff*
wak thud gush!
Mr Ree
Postby strx7 » Tue Sep 06, 2011 11:43 pm
the motor i put into the surf which from a 1996 didn't have it, nor did the one in our old supra, none of the parts motors i have, have it either, the first one i had seen was the one in our current supra
Postby MrOizo » Tue Sep 06, 2011 11:52 pm
In was only on the 6 Speed 2JZGTE's / JZA80's.
Might have been something related to the dual mass flywheels?
MrOizo
Toyspeed Legend
Postby ryanfels » Wed Sep 07, 2011 8:28 am
Have you got a picture of this dampner? My one dosnt have it but i surpose thats because its from a JZS147
thegreatestben wrote:It's lucky you arent a douchebag other wise I wouldn't help you :wink: :wink:
mark 2 gx61 2jzgte powered - viewtopic.php?t=72619&start=0
Discussion - viewtopic.php?t=72620
ryanfels
Postby Mr Ree » Wed Sep 07, 2011 10:51 am
MrOizo wrote:In was only on the 6 Speed 2JZGTE's / JZA80's.
I have seen one on an SZ-R before, and I believe thats what Shane is reffering to, too.
wak thud gush!
Mr Ree
Postby MrOizo » Wed Sep 07, 2011 1:42 pm
Oops my bad! Will be 6 Speed in general. :oops:
Forgot about the SZ-R's!
MrOizo
Toyspeed Legend
Postby strx7 » Wed Sep 07, 2011 2:25 pm
yeah it must be a dual mass flywheel counter acting something, cause yeah its on our 6 spd szr
Postby 92mr2paddy » Wed Sep 07, 2011 7:23 pm
havent got a picture of the damper but yeap mine is a 6sp but has aftermarket flywheel n twin plate clutch so should be sweet!? , i will see how i go about the belt sizing when i get the new waterpump etc,
92mr2paddy
Postby Mr Ree » Tue Sep 13, 2011 4:22 pm
Here you go fella, all the info you need regarding the damper.
http://mkiv.com/techarticles/auto_to_6s ... on_damper/
wak thud gush!
Mr Ree
Postby MrOizo » Mon Feb 06, 2012 4:39 pm
Can confirm!
Stock belt is: 6PK1940
A/C gone is: 6PK1900
Not guessing - just did this over the weekend ;)
MrOizo
Toyspeed Legend
Users browsing this forum: Google [Bot] and 26 guests
