BlakeNZ wrote:Sean wanted 14k for it last time i saw. 350 hud kw on a dyno that reads 10 percent higher than a dyno dynamics/torque performance rolling road dyno.
i can't work out how it made 350 on stock injectors, when the same tuner says my ex soarer ran out of fuel at 325 kw with 540cc injectors and 044 pump. still confused.
Yems, have you got good facilities? eg hoist/workshop etc?
Mr Ree wrote:Your dyno result sounds closer to reality based on what you said in your post about fuel running out. 370kw on 440's is stretching it juuust a bit.
Lith wrote:Lol this moved off topic quite quickly. Not everyone are building track cars, especially when they are Cressidas.
sergei wrote:Say a 2.0 500Hp GT4 with massive turbo will be slower than 300Hp with smaller turbo on the track (having everything else equal).
Snoozin wrote:Whatever happened to just doing something because you could? Not because it had to be fit for a certain purpose.
The car is clearly safe because it hasn't been written off into a tree/bank/post/truck...
2jayzgte wrote:Lith wrote:Lol this moved off topic quite quickly. Not everyone are building track cars, especially when they are Cressidas.
Yep maybe not but at the end of the day you still want to be able to drive it safe and I'm guessing this guy with this car hasn't got the 1. the brakes to handle the power 2.the suspension set up to use the power either 3.the rubber to put the power down so whats the car good for burn-outs and Dyno runs.....Yeah Next.
Users browsing this forum: Majestic-12 [Bot] and 21 guests
