4AGE Clutch/Fywheel torque settings
Postby ke_25 » Mon Oct 03, 2011 7:56 pm
Hey,
Does anyone have off hand the torque settings for the pressure plate and flywheel bolts on a 4age 20v. I am running ARP flywheel bolts if it makes any difference.
Cheers,
Shaun
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby QikStarlie » Mon Oct 03, 2011 8:26 pm
need to torque the arp's to what arp recommend for there bolts. im sure google will tell you, if you don't have the packaging anymore
QikStarlie
Postby ned07 » Mon Oct 03, 2011 8:31 pm
http://arpinstructions.com/index2.php?s ... bolts-home Just enter your kit number and it should give you the values. :)
ned07
Re: 4AGE Clutch/Fywheel torque settings
Postby allencr » Tue Oct 04, 2011 6:10 am
ke_25 wrote: ... ARP flywheel bolts if it makes any difference.
Their value comes from tightening them more. Tension.
If the fastener is only in shear, then it would do more & be stronger then the factory stuff without being tightened more, otherwise the improvement comes from holding the parts together more tightly.
allencr
Postby pc » Thu Oct 06, 2011 6:48 pm
Haynes manual says:
Clutch pressure plate-to-flywheel bolts = 14 ft-lbs
Flywheel bolts = 58 ft-lbs
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
