kiwi4agze wrote:Read the error codes, is it due for a service, the Fords check engine light comes on when its due for a service..
Otherwise normally its the o2 sensor or the cat sensor.
KiwiMR2 wrote:Would using 91 instead of 98 play a part?
Weegee wrote:...as for some of the fuel suggestions. LOL. but yes, higher compression engines should be using higher octane.
RS13 wrote:Weegee wrote:...as for some of the fuel suggestions. LOL. but yes, higher compression engines should be using higher octane.
Which suggestions are "LOL"?
Weegee wrote:but I see no need for putting 98 into a 1nzfe. sounds like a false economy to me
