Tilton twin/single clutches -W5X,4age/ze,2jzgte,1J/2J etc
Postby Bazda » Sun Oct 02, 2011 8:01 pm
We have been using Quartermaster clutches since 2006 and had great results. But recently switched to Tilton and have been getting even better results!
These are one of the most robust clutches I have come across. Never had one fail and never had one slip! Driveability is great and pedal feel is nice and soft.
So now we can offer these to all you Toyspeed members!
Tilon Twin plate & single plate clutches
All clutches supplied are the Rally Cerametallic drive units. These utilise thick 0.250” thick clutch plates which are able to be slipped and able to hold 700WHP+ on the twin applications. Single disc applications up to 350WHP
These are very popular in the USA esp for Evo drivers. Super robust units!! and not too bad for daily road use!. We have heaps of Corolla Turbo guys running these now! they all love the way they feel and grip.
- Custom kits with billet flywheels and release bearings
- Hydraulic bearings also available from $300
- Triple plate also available for the super high hp applications.
Full Bolt on Kits:
Toyota Corolla 4age/ze FWD, RWD (T50/W5x) Super light weight Single plate (rated to 350whp) $1500
- Billet 5kg flywheel
- Billet bearing cradle
- Specially designed conical bearing which makes pedal pressure very soft.
- Bolt kit
Toyota Corolla 4age/ze FWD, RWD (T50/W5x) twin plate $1800
- rated to 650hp
- Billet flywheel 5kg
- Bolt kit
http://www.mrpltd.co.nz/product/111/4ag ... wd-29.html
Toyota 1J/2J/1uzfe to W55 or R154 $1850 - Special $1800
- Optional Hydraulic bearing setup +$200
- Will have to use the Auto ring gear, can supply for extra $100.
http://www.mrpltd.co.nz/product/188/1uz ... h-w55.html
Toyota Supra Twin Turbo with Getrag 6 speed $1900
- Rated to 1000hp
- Custom billet flywheel
- Hydraulic release bearing kit
- All hardware for installation
Other models:
Mazda RX7 FC/FD
Honda (Vtec)
Nissan RBs
Mitsuibishi Evo 1-3
Mitsubishi Evo 4-8
Postby Prymal » Sat Oct 08, 2011 4:34 pm
do they do a setup to suit the st205 baz ?
St205 NZ New Group A WRC Gt4- Accept no Imitations !
Prymal
Postby Bazda » Sat Oct 08, 2011 4:49 pm
Hey, I actually custom make the kits and yes I can do one for a st205 :).
Postby Bazda » Thu Oct 20, 2011 10:00 pm
We are having a special month on our twinplate clutch kits
Postby Bazda » Fri Jan 13, 2012 8:28 am
Additional of -
2jzgte 8.5" Twinplate to fit the stock getrag 6 speed boxes
1J/2J conversions with W5X or R154 boxes
Postby Bazda » Tue Nov 20, 2012 3:45 pm
Bumping this up. Super popular amongst the 1uz/2J guys!
Postby AE82 FXGT » Tue Nov 20, 2012 4:34 pm
Can you do anything along the lines of a pull type clutch for a 13b-rew RX7?
AE82 FXGT
Postby Bazda » Tue Nov 20, 2012 6:28 pm
AE82 FXGT wrote:Can you do anything along the lines of a pull type clutch for a 13b-rew RX7?
We can do the clutch & flywheel and supply an additional hydraulic release bearing setup. I would need to find out the price on the TOB setup as the mazda needs a different setup to the toyota stuff.
Postby AE82 FXGT » Thu Nov 22, 2012 8:16 am
Yeah if you could price that up that would be sweet, it's from a series 6 rx7,if that helps. The whole engine and gearbox is going in an mx5.
AE82 FXGT
Return to Toyspeed Sponsors
