And I thought CVTs and wankels were cool
Postby GDII » Fri Sep 09, 2011 4:28 pm
http://www.youtube.com/watch?v=0CmGJucRDBk
Seems a bit odd. But works in theory.
(stolen from another forum)
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Lith » Fri Sep 09, 2011 5:03 pm
There have been all sorts of interesting designs I've followed over the last decade or so, only one I've seen actually running is the Scuderi engine - will be interesting to see if that gets a bit further than the rest seem to.
2007 Mazdaspeed Axela
Lith
Postby Grrrrrrr! » Fri Sep 09, 2011 5:18 pm
Sealing looks like a challenge, and those guide grooves will wear pretty quick if the oil film breaks down.
Grrrrrrr!
Postby VR-4Squid » Sat Sep 10, 2011 12:13 am
I agree, sealing that (and keeping it sealed for a reasonable lifespan) will be tricky. There are a lot of faces that will require precise machining too.
The biggest hurdle to mass production I can see is that it isn't modular or easily scaleable to cater different power requirements.
With a conventional piston engine you can use the same rods, pistons, valves etc for a family of 3,4,6,8 cylinder engines (or the same block/crank with different size bores).
With a Wankel rotary you can use 1,2,3 or 4 rotors.
Imo variations on the internal combustion theme are not the answer, after more than 100 years of continuous development the IC's efficiency is only ~25%
SquidInc Custom CARtoons
VR-4Squid
Postby amdeman » Sat Sep 10, 2011 9:31 am
That is thinking out of the box!
Imagine being able to.say that there's two large hairy balls under the hood...
amdeman
Postby hsmidy » Sat Sep 10, 2011 10:51 am
like so many things in life great in theroy, but not so practical
hsmidy
Postby RedMist » Sat Oct 22, 2011 8:20 pm
Space used for one cylinder is huge. I do like the pre-chamber intake idea. Basic supercharging.... for free.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby cogent » Sat Oct 22, 2011 11:32 pm
Mate are you saying rotarys arnt cool?
cogent
Postby RedMist » Sun Oct 23, 2011 7:13 am
cogent wrote:Mate are you saying rotarys arnt cool?
Not at all. Rotaries have six to twelve power strokes per rotation. This thing has one, in a casing that appears bigger than a 13b.
I am truly dissapointed that Mazda pulled the plug. Especially as I own a 13b and it's going in my new offroader.
RedMist
Users browsing this forum: Bing [Bot] and 2 guests
