Anyone got a beams motor with the intake manifold off?
Postby RomanV » Thu Oct 27, 2011 11:15 pm
Hey guys,
On my motor there's quite a substantial 'mismatch' in size between the base part of the intake manifold, and the ports.
Just wondering if this is normal?
I'm thinking that normally the port might match with the base part of the intake manifold, but has perhaps been widened.
Otherwise I'm thinking this could be something to do with air mixing with fuel as best possible, (as this is near the injector) or to minimise reversion or something.
Does the gasket normally sit near flush with edge of head, but lots of overlap on base part of manifold?
Like so:
Intake manifold:
Head:
I'm thinking that there could be some benefits by matching the upper wall of the intake manifold section to the top edge of the port.
Thoughts?
Postby xsspeed » Fri Oct 28, 2011 9:04 am
I can take a look at mine over the weekend if I have time. Might even bolt on the ITB's I got from truenotch for a geez
Edit: how are you using the stock plenum for RWD though?
Postby RomanV » Fri Oct 28, 2011 9:16 am
I'm using the stock Altezza manifold.
However the base part of the manifold, and the rubber insulator part, are the same across all beams motors, rwd or fwd.
Postby xsspeed » Fri Oct 28, 2011 9:18 am
Ah I see now, if I get a chance I'll whip them off and take some pics/measurements
Postby mr_monkey » Fri Oct 28, 2011 9:35 am
I'm surprised that the head matches the gasket as well as it does! nearly looks like its been opened up to match.
Every gasket/port that I have ever looked at has pretty much been like your first photo.
Man those beams heads are nice 8)
Edit:
Dont forget about tomorrow 8)
Previous rides: 1992 Toyota Trueno, 1992 Nissan GTI-R, 1985 Toyota AW11, 1990 Toyota SW20 Turbo, 1994 Toyota Supra Twin turbo, 1991 Toyota Soarer Turbo, 1991 nissan Safari
Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey
Postby Truenotch » Fri Oct 28, 2011 7:03 pm
That's pretty normal Dave, mine have all been like that.
There could be gains from smoothing it out, but there's only one way to find out ;) .
Truenotch
Postby Celica RA45 » Fri Oct 28, 2011 10:37 pm
dave i dont open cylinder head up at all ,the gasket on my head is the same as your inlet 5mm all around ,we pick up more power on the exhaust ports
Celica RA45
