Bringing a car out of hibernation
Postby strx7 » Tue Nov 08, 2011 5:01 pm
we've had 3+ year old petrol which smelt and burnt fine. and i've also had 12 month old gas which has been pungent and truely gone off
Postby Dell'Orto » Tue Nov 08, 2011 5:54 pm
Mr Revhead wrote:Should be fine then 8)
As a habit I do mine every autumn
Moist decent coolants are 5 year/100,000 so ought to be fine. Just change the brake fluid and gas and do skids 8)
Postby Mr Revhead » Tue Nov 08, 2011 7:20 pm
Yeah I just do that coz it's cheap and otherwise I'd forget!
Postby MAGN1T » Tue Nov 08, 2011 7:27 pm
It might pay to put a new battery in it or better still get a good one from pick a part.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Emz » Tue Nov 08, 2011 8:12 pm
I have an adapter that lets me plug the car into the mains to recharge the battery. The battery is fairly new
'97 Supra RZ - Click Here! | Discussion thread - Click Here
Emz
Miss Supra Princess
Postby rollaholic » Tue Nov 08, 2011 9:41 pm
its generally considered best to ignore magn1t.
although, i am interested in the aforementioned 5 pages of 'discussion' about fuel.
Postby BZG Wagon » Tue Nov 08, 2011 9:59 pm
CNN seems like a fairly reputable source.
http://articles.cnn.com/2008-04-09/living/aa.bad.gas_1_gas-water-contamination-fuel?_s=PM:LIVING
Can fuel go off? Yes.
[/thread]
BZG Wagon
Postby loudstealthGT-Four » Tue Nov 08, 2011 10:03 pm
MAGN1T wrote:It might pay to put a new battery in it or better still get a good one from pick a part.
Steve
Maang, is you crazy???
loudstealthGT-Four
Postby Dell'Orto » Tue Nov 08, 2011 11:10 pm
Would make sense if the battery had been connected the whole time it was in storage, would be deader than a dead thing if so. If not then it'll be fine, batteries can (and do) sit for months no problem
Postby B_giB » Wed Nov 09, 2011 8:10 am
Steve
Is there such thing as a good battery from pick a part?
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby MAGN1T » Wed Nov 09, 2011 4:20 pm
rollaholic wrote:its generally considered best to ignore magn1t.
http://www.exploroz.com/Forum/Topic/775 ... on_so.aspx
Carburettors are a bit different because the float bowls are vented, the carby will corrode and the white powder created will block the jets.
Modern cars, the tank is effectively sealed, the vent being through the carbon canister, unless it's been removed.
Steve
MAGN1T
Postby Mr Revhead » Wed Nov 09, 2011 4:23 pm
So you are basing your claim on that?
Postby MAGN1T » Wed Nov 09, 2011 6:03 pm
Mr Revhead wrote:So you are basing your claim on that?
No , just personal experience after being a hotrodder for over 30 years and fixing lots of old shitters.
Steve
MAGN1T
Postby rollaholic » Wed Nov 09, 2011 6:58 pm
Steve
arent you the guy that goes on about not believing everything you read on the internet?
or is that only if it doesnt back up your opinion?
thats a seriously weak source!
Postby tsoob » Wed Nov 09, 2011 7:36 pm
lolz
fuel goes off. its a fact.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Luke - BZG » Fri Nov 11, 2011 4:01 pm
Steve
Just fire it up, done it many a time, Batteries never loose their "charge" it's just another internet myth.
Luke
Luke - BZG
Postby DVSMOTORSPORT » Fri Nov 11, 2011 7:58 pm
Fuel will go off over time, being exposed to air makes it go off faster, eg in a carb the fuel in the bowl will go off faster than in the tank, and systems with a charcoal canister will be even slower.
Over 12 months in a system with a charcoal canister you should be fine, like strx7 said, just run it low then put fresh stuff in it, maybe change the fuel filter as well once you put fresh gas in just incase it picked up some crap from the bottom.
If its turboed then I wouldnt be thrashing it till it has some new fuel in it incase its volatility/octane has been reduced.
Thats my thoughts anyway.
Hi Im Ben, Have a nice day :)
DVSMOTORSPORT
Postby rollaholic » Fri Nov 11, 2011 8:55 pm
i'd really like to know where people get this 'picked up some crap from the bottom' stuff from, and what relation the fuel level has to it.
Postby wde_bdy » Fri Nov 11, 2011 9:01 pm
There is often crap floating around in the tank, the lower the fuel level the less fuel it has to float in and the more chance it get sucked up the fuel line.
Callum
wde_bdy
Postby rollaholic » Fri Nov 11, 2011 9:03 pm
crap in tank, sure.
floating, not so sure.
causing problems, possibly.
fuel level related, not so sure.
