ST165 Off the shelf aftermarket big brakes.
Postby sergei » Wed Nov 09, 2011 8:32 am
I am looking for off-the-shelf after market (ie Willwood, Brembo, AP etc.) brake upgrade for ST165.
The reason why I want aftermarket is that I can just buy a set of rotors when I need to, without machining anything. Additionally choice of pads is better.
I hear mixed stories about Race Brakes, what are your experiences (I am going to flick them an e-mail)?
What are other alternatives?
I am after ~300mmx~30mm, 4 pot callipers.
What are my options?
Postby strx7 » Wed Nov 09, 2011 10:21 am
chances are pretty good that some of Bazda's corolla adapter will bolt straight on for you.
Postby Shrike » Wed Nov 09, 2011 10:47 am
the ae111 front hubs and the st185 front hubs have the same bolt spacing as I have run st185 brakes on a mac setup ae111 with no mods so bazdas kit should work just dont get it redrilled for 4 stud :)
Shrike
Postby MilfHunter » Sun Nov 13, 2011 2:04 pm
Most are just using the ST205 brakes, cheap & looks good.
Tui has fitted some and the new motor running, let us know how you get on and let's see the car sometime
MilfHunter
Postby strx7 » Sun Nov 13, 2011 8:54 pm
MilfHunter wrote:Most are just using the ST205 brakes, cheap & looks good.
people often use them, yes, cheap (not really) as they are not easy to find.
be cheaper to go with aftermarket calipers than with St205 calipers
