Fidanza Aluminium Flywheels & Chromoly Flywheels
Postby Bazda » Fri Aug 05, 2011 9:56 am
Hey Guys,
We had a small shipment of Fidanza flywheels landed.
Fidanza aluminum flywheels
Made from 6061 T6 aluminum. The material is fantastic for strength, heat dissipation and of course reduction in weight.
Friction surface is icredibly strong 1045 steel.
Can mate with any type of clutch material: organic, kevlar, ceramic, metallic and sintered iron.
Replaceable friction plates there is no need to replace the entire flywheel when the clutch or flywheel is at the end of it's life, saving time and money.
We dont have many Toyota ones available as Fidanza are taking ages to make them.
http://www.mrpltd.co.nz/browse/29_102_1 ... oyota.html
Toyota Celica 88-93 3SGTE AWD / MR2 4.5kg
$500 incl GST
Will fit 5s conversions as well.
Glanza 89-99 1.3L 4efte / GT starlet 89-99 3.6kg
$500 incl GST
Corolla/MR2 AW11 4agze 88-89 3.85kg
$580 incl GST
Corolla 90-91 4age 212mm 4.1kg
$525 incl GST
We also have Nissan Silvias, Mazda GTX, Mitsi Evos and Honda Vtecs.
_______________________________________________________________________
Chromoly Flywheels:
Toyota Corolla 200mm 4age 4.1kg
$400 incl GST
Toyota Supra Turbo 87-92 6.5kg
$450 incl GST
Toyota Celica 88-93 3SGTE AWD / MR2 5.2kg
$430 incl GST
Toyota 2zzge 6-speed 00-05 5kg
$450 incl GST
Also doing Mazda RX7, MX5, Mitsi Evos, Subaru, Honda.
Postby Rick » Fri Aug 05, 2011 5:43 pm
Any for the 2zzge?
Postby Prymal » Fri Aug 05, 2011 7:04 pm
for the uneducated baz - whats the benifits between the two wheels ?
St205 NZ New Group A WRC Gt4- Accept no Imitations !
Prymal
Postby Bazda » Fri Aug 05, 2011 7:53 pm
Rick wrote:Any for the 2zzge?
I can order this from Fidanza for sure Rick.
2zzge 6 speed ones are $600 inc GST.
Postby Bazda » Fri Aug 05, 2011 7:55 pm
Prymal wrote:for the uneducated baz - whats the benifits between the two wheels ?
They are light weight!
The alloy ones are of course superior! but they cost more.
And because the friction surface can be replaced they flywheel will last forever.
Chromoly ones are just more cost effective.
Postby DeeCee » Sat Aug 06, 2011 2:08 pm
Hey baz,
Do the 3sgte ones have the elongated holes for the bolts? looking at 5s build in the future
Cheers dc
GT Four Adovansu
DeeCee
Postby Bazda » Sat Aug 06, 2011 7:46 pm
DeeCee wrote:Hey baz,
Cheers dc
Hey, elongated holes?? No they are just straight through holes.
You can view it here if you have FB
http://www.facebook.com/photo.php?fbid=252910874733842&set=a.252910788067184.69021.240947445930185&type=1
Postby Bazda » Sat Aug 06, 2011 7:47 pm
Rick, I actually have the Chromoly ones for 2zzge as well!
They are $450
Postby pureadrenalin » Tue Aug 09, 2011 2:05 pm
Cheers dc
DeeCee, I was wondering the same thing.
Bazda, what he's asking is are the holes to the crank slotted? The PCD of the 3S vs 5S is slightly different, and Fidanza started making them a universal fit for these two engines
pureadrenalin
Postby Bazda » Tue Aug 09, 2011 2:21 pm
Cheers dc
Ok I will check tonight. These are their fresh batch made last month! So if they changed it to a newer design this will be it.
Postby Bazda » Tue Aug 09, 2011 10:27 pm
Cheers dc
Holes are not elongated. Just normal straight through holes.
But if you wanted it to fit a 5S I can easily elongate them for you on the CNC.
Postby deaf_rattle » Tue Aug 09, 2011 10:57 pm
$475 incl GST
7mgte/r154 set up? or what?
Postby Bazda » Tue Aug 09, 2011 11:23 pm
new_breed wrote:Toyota Supra Turbo 87-92 6.5kg
$475 incl GST
3.0L turbo 7M-GTE
Thats all i got from the Manufacturer..
Postby Bazda » Thu Sep 29, 2011 5:35 pm
Just a quick bump.
The 3sgte flywheel also fits 5S as I found out I was looking at the wrong flywheel at the time someone above asked!
Postby Bazda » Mon Nov 14, 2011 11:18 am
Price drop on the 3sgte & 4efte fidanza flywheels!
$500 incl shipped anywhere in NZ!
3sgte one also fits 5s conversions as the holes are elongated.
Return to Toyspeed Sponsors
Users browsing this forum: Google [Bot] and 1 guest
