What i wanted to know is, is it possible for the fragments from the exhaust wheel to be projected back up the manifold into the engine?
Akane wrote:Yes, that's how I blew up my first 450hp CT26 and my 3S-GTE.
was doseing it back in 2001, and a lot of boost
nek minnit....... actually it was more like 3 months later, back to normal boost and BOV, driving home normally and car randomly stalled.
Checked compression: 30, 0, 0, 0 or some shit.
Bores all fuct.
Was doing about 0.5 bar on partial throttle around 4k rpm.
Still have the fuct wheel, looks like someone took all the fins out and you're left with a core.
Dell'Orto wrote:You'd be unlucky for it to happen - do you still have a cat?
Al wrote:I'll have a spare CT26 available tomorrow.
I wouldn't much for it, maybe $100 since you are turbo less
AE82 FXGT wrote:maybe crazy idea, but could you take the plugs out and twirl a magnet around in each bore before you start it up again? Just in case?
(btw, not sure what the fins are made of...)
Akane wrote:I had a factory cat on mine, were you boosting while it happened?
I think your engine is toast.
Al wrote:Pottery isn't magnetic
loudstealthGT-Four wrote:Akane wrote:I had a factory cat on mine, were you boosting while it happened?
Yea was about 3000rpm and 6-8psi
I'm thinking that to, but secretly hoping not
loudstealthGT-Four wrote:So today my turbo gave up, exhaust wheel went bang.
