Is there anywhere I can rebuild TRD suspension?
Postby hare » Wed Nov 16, 2011 10:16 pm
not coil over type,just the black colour non damper adjustment version,I think one might be leak since it rubbing on one side,look little lower on one side as well. :cry:
hare
Postby Girvs » Thu Nov 17, 2011 8:17 am
Pretty sure you can. 2JZGTE on the forums knows what is required to rebuild his, so providing you can find out whatever bits need to go in, then it should just be the case of sending them off to a suspension place and tell em what you want.
Girvs
Postby Bazda » Thu Nov 17, 2011 1:56 pm
Suspension tech does this.
To rebuild shocks on coilovers is $250+gst per corner.
Rebuilding a non adjustable should we pretty much be the same.
Postby Mr Revhead » Thu Nov 17, 2011 2:37 pm
Coryns ones are Bilstein/TRD which are different from what hare has I suspect. They will likely be KYB or Tokicio. I'm not so sure they can be rebuilt.
Try the suggested place or Racelign
Postby Bazda » Thu Nov 17, 2011 3:29 pm
Yea Alfreds could be sealed units.
Postby TRD_ZERO » Sat Nov 19, 2011 9:43 am
I took one of my rear coilovers trd kybs to suspensiontech and he said they can't be rebuilt. He can however put bilstein inserts in for 450 a corner. Bargain!
Previous:
TRD_ZERO
Postby hare » Fri Dec 02, 2011 1:04 pm
yeap,mine one is the blue colour non adjustable one.I end up put the factory shock back on with the TRD spring,it's only a road car so don't want to spend too much on it.thanks everyone for ideas~!!!
Bazda wrote:Yea Alfreds could be sealed units.
hare
Users browsing this forum: Majestic-12 [Bot] and 24 guests
