diesel inboard question. marine
Postby gleem » Mon Nov 14, 2011 10:12 pm
looking at purchasing a boat and really keen on diesel inboards for low running costs. Looked at 7 or so now and all the others on trade me. Why are all the engines all most prehistoric in design etc. I couldnt find one that has a good modern ish motor. Is it not common to upgrade to a mid 90s car motor in boats. any ideas? thanks
gleem
Postby strx7 » Tue Nov 15, 2011 6:39 am
cause it's like that, and thats the way it is.....
alot of the yamaha 6 cylinder diesels are just marinised 4.2 cruiser motors. but in the 4 cylinder range its generally old school stuff. i have heard of a number of 1kzte being put into boats, and they use a 14BT injector pump on them to keep it all mechanical.
Postby Barks » Sun Nov 20, 2011 9:39 am
+1 on that..... a marine conversion on the average 90's diesel would cost way more than the engine, so people don't do it!
The Nissan LD engines do seem to feature in marine conversions quite heavily though - I'm picking that Nissan may have done a production run of marinised versions.
Basically most of the older boats feature primitive engines solely because there was no alternative. These days a lot of people that come in for propellers have done conversions to Yanmar marine motors, so I'm picking they're pretty low cost, though Volvo Penta is still a popular choice, and John Deere have just released a new range of marine 4s.
Did repairs on a pair of 27 x 25.5 props last week that live off the back of 650hp Cats... THOSE are modernish engines!
"Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music"
Kristian Wilson, Nintendo, Inc, 1989
Latest rides: 2004 Avensis Wagon, GT Avalanche 1.0, GT Avalanche 0.5, Marin Toscana CX
Barks
Postby Grrrrrrr! » Sun Nov 20, 2011 10:43 am
And the fact that if you're 20kms from dry land the last thing you want is an ecu failure :)
Grrrrrrr!
Postby gleem » Sun Nov 20, 2011 5:33 pm
I realise the injection should be kept mechanical, but what is marinising? I was assuming youd have to do some Custom fitting to get it to bolt to whatever they bolt to
gleem
Postby evil_si » Sun Nov 20, 2011 6:58 pm
Marinisng refers to how an engine is setup for marine application,
The Cooling system is very different to automotive, and utilises a heat exchanger, raw water pump, anodes,
Exhaust manifolds and turbo exhaust housings are water cooled
Basically the raw water pump sucks from outside the boat, pumps it thru the heat exchanger ( fluid to fluid marine radiator ) which cools the engine coolant, it then exits thru the exhaust manifolds to the sea again,
Anodes are fitted in the cooling system as sacrificial blocks (There is always stray electrical current and the different metal reactions eat away marine engines badly,)
water cooled manifolds keep the engine room temps down and gets
evil_si
Postby evil_si » Sun Nov 20, 2011 6:59 pm
There are also plenty of engine manufacturers that make electronic diesels for marine use,
evil_si
Postby gleem » Sun Nov 20, 2011 8:57 pm
oh ok so that in the scope of things is nothing really. Im seriously in the market for a boat and have a list of motors id like to drop in 3ct being on the top of the list
gleem
Postby fangsport » Sun Nov 20, 2011 9:02 pm
gleem wrote:oh ok so that in the scope of things is nothing really. Im seriously in the market for a boat and have a list of motors id like to drop in 3ct being on the top of the list
have been helping a guy set up the 2CT into a factory modified Mac hull with a jet behind it.
will get back to once the unit has been trimmed correctly, as to how is goes.
fangsport
Postby gleem » Sun Nov 20, 2011 9:08 pm
will go have a look at this this week
http://www.trademe.co.nz/Browse/Listing ... =397105576
25hp sounds pathetic for a 20foot steel boat. I really have something personal about primitive engines so a 2cyl isuzu form 1981 would have to go.
gleem
Postby Bling » Sun Nov 20, 2011 9:12 pm
Wow, never seen such an ugly boat :lol: What is it actually designed to be used for? Apart from going slow and getting laughed at.
Postby kiwi4agze » Mon Nov 21, 2011 8:58 am
Just remember any engine can be converted to mechanical fuel injection...
kiwi4agze
Postby xsspeed » Mon Nov 21, 2011 9:04 am
What size boat/hp motor do you want (forgetting about engine types for a bit)
Postby Mr Revhead » Mon Nov 21, 2011 9:05 am
Yikes 25hp in that?
Check your tides!! :lol:
Postby gleem » Tue Nov 22, 2011 7:04 pm
i know its the most hedious thing around. I would rebuild the cabin. I dont have much experience in this but 70 hp?. Im just juding weight to petrol out board power experience i have.
gleem
Users browsing this forum: Majestic-12 [Bot] and 22 guests
