Fuel Consuption for a 4agze with supercharger removed
Postby kiwi4agze » Tue Nov 22, 2011 7:23 am
I need to find out how much fuel a 4agze with the supercharger removed would get thru at idle per hour, a rough ball park figure is ok but if anyone knows exactly it would be great.
Silly question I know but its actually pretty important.
It will still be running the low comp pistons.
kiwi4agze
Postby fevil » Tue Nov 22, 2011 8:44 am
At idle it will burn the same amount, whether the supercharger is there or not.
fevil
Postby kiwi4agze » Tue Nov 22, 2011 8:45 am
Which is how many L per hour?
kiwi4agze
Postby Mr Revhead » Tue Nov 22, 2011 8:57 am
At idle the s/c is not engaged so yeah won't make a difference.
I doubt very much anyone here will know. You will need to ask people who have used them for what your are wanting to use them for.
Won't be hard to test if you have a running one!
Postby kiwi4agze » Tue Nov 22, 2011 9:05 am
The idea was to run the 4agze to start the merlins as the merlin uses a starting cap which is now illegal to use thanks to the green party!!!
But it takes a good few hours of pre-flight checks and mantience and was going to use the 4a on a trolley setup to provide power for the mossie instead of idling the merlins. Run a bank of altenators to provide power while I work on her and use that to start the merlin.
It was just an idea as I have one sitting around and the cost of a generator would be really $$$ and made by honda.
kiwi4agze
Postby ee904age » Tue Nov 22, 2011 1:03 pm
Not really of much use at all, but my Commodore uses approx 2.5l/h at idle according to the fuel computer. Thats a 3.8 V6.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Re: Fuel Consuption for a 4agze with supercharger removed
Postby ~SlideWays~ » Tue Nov 22, 2011 1:21 pm
kiwi4agze wrote:It will still be running the low comp pistons.
Just a note that 'low comp' in a 4agze can either be 8.0:1 or 8.9:1.
Easiest way to tell is if it has/had an AFM which would mean 8.0:1.
~SlideWays~
Postby sergei » Tue Nov 22, 2011 1:51 pm
Don't forget once you load it up with alternators it is no longer idle.
With sufficient electric load you can stall the engine, unless you have throttle control to compensate.
So if you are sucking 5kW out of alternators, then the engine will consume a lot more than it would on idle.
My guesstimate at moderate load (say 5kW) you are looking at ~5-10L/h.
I could not find a chart for 4AGZE, but here is one for 4AGE 20v s/t:
basically at full throttle @ ~2000rpm it consumes ~300g / kWh, putting out about 20kW. Run it for 1 hour at that load it will consume 6L.
This consumption does not scale back. The most efficient range will be about 2500-3500rpm at full throttle for 4A.
Postby DVSMOTORSPORT » Tue Nov 22, 2011 5:20 pm
Food for thought, 4A-GZE would realey mean injection??????
Something like that Id be running the most basic carby engine possible. minimal number of wires, fuel line etc. Not sure if your thoughts were to convert to carby or not.
Hi Im Ben, Have a nice day :)
DVSMOTORSPORT
Postby sergei » Tue Nov 22, 2011 6:05 pm
4AGE is wrong engine for this.
5kW diesel generator is not that expensive.
Eg:
http://www.trademe.co.nz/business-farmi ... 192153.htm
or
http://www.trademe.co.nz/business-farmi ... 510215.htm
Postby rollaholic » Tue Nov 22, 2011 6:28 pm
4k! (forklift motor? :P)
Postby kiwi4agze » Tue Nov 22, 2011 6:32 pm
I was hoping to use it for towing at the same time, hence why the car engine.
The Merlin drink petrol at a rate which make them un-economical to run. I was going to tow it with the 4a in a simple frame and use it to power the mossie while it was on the ground.
4k i heard was a good boat anchor.
kiwi4agze
Postby gleem » Tue Nov 22, 2011 7:02 pm
let me tell you one thing for certain. It will use more that 2.5l per hour
gleem
Postby MAGN1T » Tue Nov 22, 2011 7:46 pm
It depends on how much power it's making.
Full throttle uses more than just idling.
Google up "brake specific fuel consumption"
It's in units of pounds per HP per hour or a metric equivalent.
Normally about .5 at full throttle.
An engine is at it's least efficient when idling so the figure could be closer to double.
If it's driving alternators then it's no longer just idling.
You want to fly?
I thought you were supposed to be educated in such things in order to get a pilots licence?
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Mr Revhead » Tue Nov 22, 2011 8:09 pm
Sounds like you need to buy a ride mower type thing
Postby RS13 » Tue Nov 22, 2011 8:35 pm
I'm with Sergei on this one, diesel generators are quite cheap secondhand, given that most of the air transport fleet flying in NZ 40 years ago was piston-powered, I'm willing to bet that there may be a few old 24v or 28v diesel generators lying around workshops/hangars somewhere?
RS13
Postby kiwi4agze » Tue Nov 22, 2011 8:42 pm
RS13 wrote:I'm with Sergei on this one, diesel generators are quite cheap secondhand, given that most of the air transport fleet flying in NZ 40 years ago was piston-powered, I'm willing to bet that there may be a few old 24v or 28v diesel generators lying around workshops/hangars somewhere?
Any leads a good 28v one would be great?
A lot of the old stuff has been scrapped or sent overseas.
The cheapest 28v diesel i found was in the thousands!
kiwi4agze
Postby DVSMOTORSPORT » Tue Nov 22, 2011 8:51 pm
And how much do you expect to spend on building one?
DVSMOTORSPORT
Postby RS13 » Tue Nov 22, 2011 9:02 pm
I can't recall seeing anything like that around where I work.. the only 28v dc feed we mainly use is on the ATRs and that runs off the 115v carts. I'll ask around though! I'm sure you're probably on a NZ aviation forum or two? Maybe stick a WTB ad up?
RS13
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
