This is a pretty broard but the experts here may be able to
Postby Paul Skidmore » Tue Dec 06, 2011 8:36 pm
help... I have a 1994 Caldina TZ that needs a cambelt/tensioner, waterpump change... Is it a easy enough job for a d.i.yer or is this a job for a pro... If so how much roughly would a garage charge for this kind of service...
Any help will be most appreciated
Cheers in advance
Paul :?
Never to afraid to ask
Paul Skidmore
Postby Dell'Orto » Tue Dec 06, 2011 8:36 pm
3SFE arent the TZ's? If so, piece of cake
Postby Paul Skidmore » Tue Dec 06, 2011 8:39 pm
Dell'Orto wrote:3SFE arent the TZ's? If so, piece of cake
Yup its the 3sfe motor... Does the engine need to come out?
Paul Skidmore
Postby levinguy » Tue Dec 06, 2011 8:40 pm
no
levinguy
Postby Dell'Orto » Tue Dec 06, 2011 8:44 pm
Just undo the drivers side mount, and use a jack to raise and lower it, simple as.
Postby Paul Skidmore » Tue Dec 06, 2011 8:46 pm
Dell'Orto wrote:Just undo the drivers side mount, and use a jack to raise and lower it, simple as.
Brillant... Thanks for your help!
Paul Skidmore
Postby Jdawg » Tue Dec 06, 2011 8:46 pm
Bitchiest part is taking the engine mount off.
Did the belt on my sister's Curren last weekend
Jdawg
Postby Paul Skidmore » Tue Dec 06, 2011 8:58 pm
Jdawg wrote:Bitchiest part is taking the engine mount off.
Now foe the big question... What sort of price foe a mechanic to do the work for me then? :wink:
Paul Skidmore
Postby loudstealthGT-Four » Tue Dec 06, 2011 9:08 pm
would be best to go and ask one :)
loudstealthGT-Four
Postby Paul Skidmore » Tue Dec 06, 2011 9:20 pm
Fair enough... I was cheeky in asking but it was worth a crack.
Paul Skidmore
Postby levinguy » Tue Dec 06, 2011 11:22 pm
it comes down to, what have you done before and how long without this car can you last if something goes wrong? if you can survive without it and want to do it right then go for it.
levinguy
Postby Dell'Orto » Tue Dec 06, 2011 11:48 pm
Not sure what a mechanic would charge, would assume probably 3 hours labour plus parts.
Took me about 5 to do a Rav 4 with ABS, just pottering about
Postby solitaire » Wed Dec 07, 2011 12:05 am
And I find the first time I do anything it takes at least 4x as long as it should
AE92, KZJ120, KDJ120
solitaire
Postby rollaholic » Wed Dec 07, 2011 6:01 am
its sort of one of those if you need to ask you probably shouldnt do it type jobs. they are relatively straight forward in terms of getting it all in bits, but if you are not confident with setting up the new belt its not hard to give yourself issues. having someone who knows what to do handy to check your work before you re-assemble is probably advisable if its your first time
Postby Quint » Wed Dec 07, 2011 7:45 am
Get a manual, follow instructions, turn it over by hand a few times after you've installed it (need to anyway to set your tensioner) to make sure nothing fouls.
Can't go wrong, easy job, good one to pop your cheery on.
Do your front seal at the same time. worth it while your there for a 10 dollaer seal.
Quint
Postby Sick Puppy » Wed Dec 07, 2011 11:04 pm
Quint wrote:Do your front seal at the same time. worth it while your there for a 10 dollaer seal.
Me being a n00b, what is the front seal for/to?
Oh, and don't just replace the cambelt, do the cam seals too - may not be a major now, but if they go, the engine oil will leak onto the belt, perishing the rubber and ultimately breaking it... ask me how I know. :evil: Thankfully the engine is non-interference... :roll:
You could do the waterpump too while you're there!
Project thread here
Discussion thread here
Sick Puppy
Postby Grrrrrrr! » Wed Dec 07, 2011 11:18 pm
front seal = front crank seal. the one behind the crank pulley.
Leaky front seal has same problem as leaky cam seals WRT belt damage.
Grrrrrrr!
Postby 1I1 » Thu Dec 08, 2011 1:51 pm
There's also the seal and o-ring on the oil pump (right next to the crank pulley) that start to leak
TRD Clicky >>Here
1I1
Postby Mr Revhead » Thu Dec 08, 2011 3:54 pm
Water pump is a MUST on the 3S when doing the cambelt
Postby rollaholic » Fri Dec 09, 2011 6:37 am
as above, and get a genuine one so it comes with all the little gaskets and o-rings. nothing like that big o-ring on the pipe going into the back of the pump springing a leak 6 months after you've had the cambelt off. i reckon a waterpump at a minimum is a must for any engine that needs the belt off to change it.
frankly you should be changing all the idlers and tensioners too, and the cam seal for that matter
Users browsing this forum: Majestic-12 [Bot] and 14 guests
