Light weight Chromoly Steel Flywheels...peoples thoughts??
Postby AE86fan » Tue Dec 27, 2011 6:11 pm
There are a few different brands of light weight Chromoly Flywheels on trade me at the mo and they all look pretty similar at similar prices $400-$500.
They are advertised at 3.8 kg which is about half the standard 4age weight. I want to stick with the 200mm clutch setup which discounts using a blacktop flywheel.
Just wondering if people have found them good value for money??
Im building a 20v pretty much standard except for 11.5 compression and Link with trumpets.
1984 NZ AE86
AE86fan
Postby Bling » Tue Dec 27, 2011 6:49 pm
viewtopic.php?t=84938
$400 there too
Postby Celica RA45 » Wed Dec 28, 2011 12:43 am
go with the chrom moly as the fandanza are shit ;dont trust alloy at all if you wont to keep your legs,.. are known to let go and if you are up at 8000rpm and bang there goes the box and also the motor
steel is your freind and alloy is good for inlets
Celica RA45
Postby allencr » Wed Dec 28, 2011 5:30 am
search
I claim no knowledge of ebay the manufacturers or overseas availability.
http://www.ebay.com/itm/EXEDY-CLUTCH-KI ... 0532928667
allencr
Postby Flannelman » Wed Dec 28, 2011 11:13 am
The downsides to light flywheels are low speed driving becomes hard to keep smooth and it becomes easyer to stall.
Bonus? Engine becomes more responsive as less power is lost in the inertia of the flywheel.
The ligher the flywheel, the greater these effects become.
The 212mm blacktop clutch setup will fit on these flywheels too.
Flannelman
formerly known as Affroman
Postby 85AW20v » Wed Dec 28, 2011 10:22 pm
allencr wrote:search
Add on USD$215 for freight and there's not much point......
See ya
Simon
85 MR2 20v
85AW20v
Postby allencr » Thu Dec 29, 2011 4:24 pm
85AW20v wrote:Add on USD$215 for freight...
OUCH! 8O
Also, is there any import tax/duty/tariff/whatever BS on stuff like that?
Just curious, Thanks.
allencr
Postby Dell'Orto » Thu Dec 29, 2011 6:57 pm
Only over $400NZ, but that includes freight too...
Users browsing this forum: Majestic-12 [Bot] and 15 guests
