QikStarlie wrote:from memory the earlyer ht18's ran a single scroll rear and the later ones are the massive twin scroll. but the rest of the turbo is the same. they arent super responsive even with at t3 housing on them. since the rear wheel is bigger than normal t3, compressor side is smaller than the biggest t3 wheel. they are really designed for high exhaust flow. should be good enough for you want to do though
a normal t3 with around a .48ar exhaust housing and a 60trim compressor wheel. would work good, but probably not so easy to find
evil_si wrote:Ht18 from fc series 4 or 5 rx7,
12a ht18s are a bit smaller from memory
Rb20 exhaust housing with 04U cast on the turbine inlet is the one to look for
Any good machinist should be able to machine it out. Otherwise i can arrange if you get stuck
narlystarly wrote:My 16v 4AGTE Corona made 195kw on 17psi with the HT18/RB20 hybrid with link V5 as a power comparison.
edwagon wrote:That was running 18psi of boost (20 through the midrange) on 10:1 compression
edwagon wrote:If you want more response, what about a td05?
Bazda wrote:Masterpower T04e with 0.48a/r ex housing..
iOnic wrote:You can get responsive T3/T4's. The one I put on my partner's 1300cc 4EFTE makes full boost (14psi) just after 4000rpm - .48a/r exhaust. I'd imagine a 4AGE would bring that down noticeably.
Otherwise hard to beat a twin scroll td05hr
d1 mule wrote:my old ht18 t3, ran out of puff at 15 psi on a 4agte got 230 whp out of it.
made full boost at 4200 on a 8.0:1 gze
QikStarlie wrote:we used to run straight t3's with a .30 exhaust housing and 60 trim compressor wheel, on our gt starlets, (4efte 1300cc) would get 18psi under 4000rpm. and just over with a .36 housing. 170kw at wheels no worries.
4age you'd want to run something bigger like a .48 as i said before.
would work better than ht18, but not as easy to find.
Vertigo wrote:what do you guys think of the DPR turbos?
iOnic wrote:Evo 4+ twin scroll are more responsive and generally in better condition.
