Im going to be installing a bigger radiator in my JZA80 tomorrow and I want to go back to using Toyota Red coolant (from current green) so thought that I would run a flush through to get rid of any crap inside the motor/heater before putting the new core in.
Im going to drain out as much cooalnt as possible then refill with water and run up to temp, a few times over until there is no trace of anti freeze left in the system then run the flush.
I was wondering if anybody here (preferably in the trade) that has had experience with a particularly good brand to use?
Thanks
