jaypines wrote:Bazda wrote:Whats the high costs your talking about?
if someone could just produce better aftermarket parts for the SS suspension arms... think heims or rose joints...
Mr Revhead wrote:Rose joints on a road car are a bad bad idea.
Increased harshness and even more wear!
Bazda wrote:That if you buy cheap rose joints.
Mr Revhead wrote:Bazda wrote:That if you buy cheap rose joints.
Not so. Harshness due to the obvious lack of rubber.
And due to the bearing sliding in a housing unsealed they wear out. In relatively short time on a road car. Yeah you can get seals for them, but they are only sort of good.
However if its a race car or weekend toy then go for it. But replacing s/s parts with rose joints for a car driven rather a lot would be silly as the cost would be more and they will not last as long.
sergei wrote:EDIT: I am talking about these things:
FLESHAXXE wrote:Our roads not as good as yours and we spend $975/arm(arm with ball joint) which is around $487.50 US. Anyway I'm considering giving it one last go until I change the car.The thing is I have a contact in the US at present and they need the part numbers.They don't give out part numbers here so I went on the site toyodyi.com and they removed all the diagrams.My thing is that I would like the diagrams with the part numbers because I'm not familiar with them. Can anyone help me.My chassis # is AE101-5039184 and engine #4A-2546401...These are the front left and right bottom arms with the ball joint in the center....
jaypines wrote:FLESHAXXE wrote:Our roads not as good as yours and we spend $975/arm(arm with ball joint) which is around $487.50 US. Anyway I'm considering giving it one last go until I change the car.The thing is I have a contact in the US at present and they need the part numbers.They don't give out part numbers here so I went on the site toyodyi.com and they removed all the diagrams.My thing is that I would like the diagrams with the part numbers because I'm not familiar with them. Can anyone help me.My chassis # is AE101-5039184 and engine #4A-2546401...These are the front left and right bottom arms with the ball joint in the center....
toyodiy is working for me... http://www.toyodiy.com/parts/p_G_199110_TOYOTA_COROLLA_AE101-ACMZF_4802.6.html
Grrrrrrr! wrote:no RHD ae101 superstrut cars were made.
