Help!! sidedraft ae86 wiring
Postby Peradx » Sat Jan 14, 2012 12:32 am
hey guys just wondering if any of you out there could help me wire up my car. need it going monday!
its running a 4k dissy and coil. thats been easy so far. but it wont turn over if getting a clicking from the circuit open relay and nothing else.
please help.
Peradx
Postby LEAKER » Sat Jan 14, 2012 6:34 am
Single click or multiple clicks? Is the starter motor new or second hand? Just to make sure, try tapping the end of the starter motor with a hammer. It's hard to say but maybe, just maybe the starter motor is poked. Multi clicks could signal a flat battery? Just an idea.
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Postby Peradx » Sat Jan 14, 2012 10:14 am
single click
Peradx
Postby jondee86 » Sat Jan 14, 2012 10:34 am
Check the starter by taking 12V straight from the battery positive
to the starter solenoid. If the starter cranks, then the problem is
in your wiring. And I'm reasonably sure that the starter signal to
the solenoid comes directly from the ignition key switch.
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby Peradx » Sat Jan 14, 2012 11:14 am
solved starter issue just working on spark. new coil, new resistor, new wiring. and then fuel pump. i'm thinking thant the alarm might not be helping.
Peradx
Postby Bling » Sat Jan 14, 2012 11:37 am
I get a single click and lose all electrical power if trying to start it while it's immobilised. Just incase that is helpful.
