puddle under car
puddle under car
Postby alimac » Mon Jan 30, 2012 8:44 pm
We have an old 84 Corolla II with a 2a motor. This morning my wife went out to find a puddle under the front. The air con is disconnected, and it had been sitting in the shed since Saturday. I can't find any leaks, even with high revs and a warm motor. She filled it with water and drove to work and back (about 45km return) and the radiator and reservoir are still full. Does anyone have any ideas as to where the leak might be?
Altezza RS200z6MT- Yellow
alimac
Postby Dell'Orto » Mon Jan 30, 2012 8:46 pm
Any stray dogs in the area? :lol:
Postby Grrrrrrr! » Mon Jan 30, 2012 8:47 pm
Including those of the two legged variety :)
Grrrrrrr!
Postby DVSMOTORSPORT » Mon Jan 30, 2012 9:03 pm
Waterpump leaking when there's no pressure on the seals maybe?
Hi Im Ben, Have a nice day :)
DVSMOTORSPORT
Postby alimac » Mon Jan 30, 2012 9:14 pm
Dell'Orto wrote:Any stray dogs in the area? :lol:
Actually there was one in the back yard this morning, but the car was in a closed shed, so that can't be it.
The waterpump crossed my mind, but I thought maybe not when it didn't leak with the engine running. It didn't occur to me that the pressure might stop the leak. Is this a common thing to happen?
alimac
Postby DVSMOTORSPORT » Mon Jan 30, 2012 9:27 pm
Yeh the pressure usually helps the seals do there job. Pretty common to happen. Never actually stripped one apart but pretty sure the spring on the seal either breaks or rusts.
DVSMOTORSPORT
Postby Stott69 » Mon Jan 30, 2012 10:11 pm
Could also try heater pipes?
Stott69
Postby Lurkin » Tue Jan 31, 2012 12:30 am
air con?
Past casualties
1986 4age liftback (sold)
1985 4age aw11 (well crunched)
1993 ae101 gt apex levin (sold)
Lurkin
Postby crispy'86 » Tue Jan 31, 2012 10:29 am
Lurkin wrote:air con?
He's got the a/c disconnected as said in his original post :D .
Could be water pump seals , had this same thing with customers car. With cooling system pressure tester on it 2 out of 3 times it wouldn't leak. But with the mirror and bright enough light could see it had been leaking
crispy'86
Postby Babz » Tue Jan 31, 2012 7:21 pm
Would be starting with the Water pump. Have a look at the water pump housing there should be a little hole somewhere usually pointing to the ground. Have a look with a torch if you can see any sign or traces of leak. And as DVSMOTORSPORT said water pumps usually will not leak when running.
If nothing works camp out in front of the car untill you spot a leak :lol:
1982 Carina TA63 (in the making)
1986 Corona TT141 SR20DE (Rear Ended and For Sale)
1998 Audi A3 1.8T (wifes daily driver)
2011 Mitsubishi Triton (Work Ute)
Babz
Postby AE82 FXGT » Tue Jan 31, 2012 7:24 pm
I would be finding out what sort of fluid the puddle is for a start.
AE82 FXGT
Postby iOnic » Tue Jan 31, 2012 7:29 pm
^ this
Sniff it, lick it, taste it, rub it between your fingers etc
:lol:
Postby Babz » Wed Feb 01, 2012 9:10 am
The fact that he originally said the water was filled and the car was driven makes me assume that it is water :P
Babz
Postby .:O4AGTZ:. » Wed Feb 01, 2012 9:18 am
queue experimental driveway suck
.:O4AGTZ:.
Postby Lurkin » Wed Feb 01, 2012 1:08 pm
Lurkin wrote:
air con?
He's got the a/c disconnected as said in his original post .
:oops:
Has it continued doing it/ is the water level dropping?
Have you checked the other fluids? particularly brake fluid?
Past casualties
Lurkin
Postby Mr Revhead » Wed Feb 01, 2012 1:24 pm
AE82 FXGT wrote:I would be finding out what sort of fluid the puddle is for a start.
Yes. Yourself, don't ask the woman!
Postby alimac » Wed Feb 01, 2012 7:35 pm
I did, and it was from the cooling system. It hasn't done it since. I'll keep and eye on it though.
Actually she's quite clued up when it comes to mechanical stuff. She knows how to do a valve grind and swap an engine etc.
Thanks for the help guys.
alimac
Postby DVSMOTORSPORT » Wed Feb 01, 2012 7:49 pm
alimac wrote:She knows how to do a valve grind and swap an engine etc.
8O 8O 8O 8O :wink:
DVSMOTORSPORT
Postby Mr Revhead » Wed Feb 01, 2012 10:06 pm
alimac wrote:I did, and it was from the cooling system. It hasn't done it since. I'll keep and eye on it though.
I can see why you married her then!
Good job that man 8)
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
